Minimum Distance Requirements
kevhed72
kevhed72 Posts: 5,244
For ICs and exposed 10 or 12 AWG electrical romex wire...the ICs I have in mind are MIT AVT1 / AVT2, so the shielding should be pretty good.
Also, anything I should consider wrapping around the romex to shield the current from the ICs?
(I am running my ICs behind the front wall of my HT for a clean look, and wanted to check the minimum distance first) :smile:
