SRT center
bluecomet
bluecomet Posts: 1,118
edited May 2011 in Vintage Speakers
How good is a SRT center by itself. I just bought one off ebay and I was hoping it matches up well with a SRS 7.1 system I am putting together. My mains will be SRS 1.2's, the center will be the SRT, the rears will be SRS 2's pin/blade version and the rear centers will be CRS+'s. I realize the SRS speakers were not made for HT but I thought since I have them I would see what happens. All of the SRS speakers I believe are 6 ohm with RDO 194 replacement tweets. I doubt if I need a sub. I will use an Onkyo SR805 AVR. It should be interesting.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
    nooshinjohn Posts: 25,467
    edited April 2011
    Sounds good to me. those that have heard my 2.3TL's in my surround setup have been impressed. I tried one of these for a short time however, and I found that I prefer the CSiA6 for center duty.
  • bsoko2
    bsoko2 Posts: 1,449
    edited April 2011
    I have the CS1000p with my 2.3TL's and like what I hear.
  • ESavinon
    ESavinon Posts: 3,066
    edited April 2011
    The SRT center was exclusively designed for the SRT system. As a matter of fact, The SRT center is the stereo half of the SRT mains. It may be compatible with the RT/LS series since it uses a similar tweeter but not so much with the SRS series.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • bluecomet
    edited April 2011
    If it does not sound right. I have a RT series collection of speakers it should work out with. What's the differance between the SRT center and the LS350 center speaker, they look similar.
  • civilian
    civilian Posts: 357
    edited April 2011
    I am guessing mixing and matching like you plan to do will not sound nearly as good as you other 2 systems. And going for 7 channels you don't want to run the interconnect cable between your mains (front or rear), although I'd like to try it on mine to see what it sounds like?
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
  • bluecomet
    edited April 2011
    I will use the interconnect cables on all the speakers. The SDA speakers don't sound nearly as good without the cable. All the SDA speakers match sonically. I will see how close the SRT matches. Who knows maybe this is the first piece of a future SRT system.
  • dpowell
    dpowell Posts: 3,068
    edited April 2011
    bluecomet wrote: »
    They have a similar tweeter but the mid drivers are different. I'd say that the mids are closer to what was used in the RT series that followed.
    I had my eye on that center as an insurance policy for my SRT's but was hoping he'd come down on the price a bit. Enjoy the center!
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • bluecomet
    edited April 2011
    What if the center was matched with a SRS 1.2tl with RDO 198 tweets. Do you think that would match better?
  • engtaz
    engtaz Posts: 7,664
    edited April 2011
    Try it and see what you think. Everyone has a thought on it but when it comes down to it, it is you that has to be happy.
    engtaz
  • dpowell
    edited April 2011
    engtaz wrote: »
    Agreed. Only your ears will know what sounds good.
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited April 2011
    With the right modifications and right equipment - the SRS 1.2TLs sounds awesome in 2 channel mode and will never need a center speaker.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • bluecomet
    edited April 2011
    It should be here anyday now. I am looking forward to hearing it and comparing it to other Polk centers I have.
  • bsoko2
    bsoko2 Posts: 1,449
    edited April 2011
    bsoko2 wrote: »
    And like I said in this post, I use mine in my HT in the living room (6000+ cu ft). Also scored 2 sets of RT 55i's along with the RT 1000i so I have all my surrounds the same now (wides 55i, L & R surrounds 1000i, & rear surrounds 55i. I run my system as "large" along with my Quad Empires. Ran some spl tests between large and small with the subs and prefer the large settings. More life to the audio channels.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    bsoko2 wrote: »
    Got any pics of your setup?
  • bluecomet
    edited May 2011
    I got the SRT center yesterday. It looks like it just came out of the box. So far I teamed it up with my SRS 3.1tl's and after playing around with my Onkyo SR805 I got it to sound pretty darn good at a high volume setting for music. It's impressive but I will next try this center with RT800's. I am a big fan of the RT series speakers and for what I heard from Polk reps, these should be the closest sonically in matching the SRT. I look forward to mixing and matching some of my speakers with the SRT but so far teaming this center with SRS speakers is not a bad marriage. Maybe someday I will be lucky enough to find a whole set of SRT's. I am sure that would be awesome.
  • engtaz
    engtaz Posts: 7,664
    edited May 2011
    Great to hear.
    engtaz
  • bluecomet
    edited May 2011
    I noticed on some SRT literature that Polk recommended using two SRT centers for there top of the line setup. Does anyone use two centers. I was wondering what other club members thought.
  • ESavinon
    edited May 2011
    I've used two. Not much different than using one. It's all room dependent.
  • bluecomet
    edited May 2011
    It looks like I am going to get a second SRT center. How would I hook up two center SRT's. If I don't like the how it sounds, I could always use it in a Yamaha 6.1 system as my rear center.
  • dorokusai
    dorokusai Posts: 25,577
    edited May 2011
    I'd stick with one.
  • ESavinon
    edited May 2011
    bluecomet wrote: »
    In series. 4+4=8 Ohms.
  • engtaz
    engtaz Posts: 7,664
    edited May 2011
    ESavinon
    SRT Specialist is the SRT man.
    engtaz
