polk speakers
fryedspeakers
repairing rti 10,s and rti 6,s any help
Post edited by fryedspeakers on
A little more help in what you need would help us in what your after..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Yeah, otherwise you might get snarky comments from mean Club Polk members.Do you hear that buzzing noise?
Monster Jam wrote: »buy new speakers
By "snarky", you must mean this.HT SYSTEM-
lsi 9's -
TO ERR IS HUMAN. TO FORGIVE IS CANINE.
i guess they would make a nice bon fire ....
Monster Jam wrote: »Yeah, otherwise you might get snarky comments from mean Club Polk members.
Great info thanks!!! I will look into it..:rolleyes:
Snarky enough for you?
Thanks for helping out.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
fryedspeakers wrote: »i guess they would make a nice bon fire ....
What is going on with them? what are they doing? if anything?? Have you pulled the crossovers??
A little more info of whats going on with them would help greatly!!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
no sound shuts. down soon as connected, pulled speakers out of cabinets. have not removed cross over yet ...
What are you powering them with? What volume level were you listening to them?Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Sounds like a receiver problem as I have a hard time seeing you fried allspeakers at once..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
they didnt all go at once, avr stays on with no speakers connected. i do like to crank up the volume once in awhile.
Check your Crossovers then, what AVR are you using??Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Have you tried hooking the speakers up to a different AVR?
Have you tried a different set of speakers (other than the ones mentioned in this thread) on the AVR?
Have you tried hooking only one speaker up to the R channel?
Have you tried hooking only one speaker to the L channel?
Have you tried hooking up a different speaker to the R channel?
Have you ...
Running an AVR without any speakers hooked up to it does not prove that the AVR is in working order. What other tests have you performed to verify that it is indeed the speakers that are causing your receiver to shut down? As others have said, more information is needed. -
ran a test with spare rti 6,s had in garage. front left and right and surround channels work.i guess theres nothing wrong with the hk avr 8000.... not sure what i,m looking for with the cross over, should it be tested with meter ???? thanks for the suggestions...
