Polk SDA 1.2/1.2TL and subs?
thejck
thejck Posts: 849
edited May 2011 in Vintage Speakers
How many of you SDA owners with properly setup/amplified SDA's add subs for your 2 channel pleasure?
I am still thinking about building me some subs and I wanted to see if I should just worry about them for the HT part of my room or try and integrate them into my 2 channel rig as well.
Post edited by thejck on
  • nspindel
    nspindel Posts: 5,343
    edited April 2011
    Sal has a sub with his 1.2TL's
    Toolfan66 Posts: 18,070
    edited April 2011
    No sub for me!!!!!
  • nspindel
    edited April 2011
    Me neither, and I just have 1C's.
  • dpowell
    dpowell Posts: 3,081
    edited April 2011
    No Subs on my 1C's. Do the other forum-recommended upgrades if you haven't already and you won't need a sub.
  • thejck
    thejck Posts: 849
    edited April 2011
    dpowell wrote: »
    Its not that I feel I need a sub. Its just that I am trying to build a plan of what to do.
    I have done a few of the upgrades already. I will be trying out DK's inductors soon and I heard that is supposed to bring out a lot more bass in the 1.2's
  • thejck
    thejck Posts: 849
    edited April 2011
    nspindel wrote: »
    Too Sal,
    care to pass along your thoughts on the matter.
    heiney9 Posts: 25,445
    edited April 2011
    Properly set-up and powered SDA's shouldn't need a sub, unless you are in a very, very large listening room. Even then probably not.
  • newrival
    newrival Posts: 2,017
    edited April 2011
    It depends on what you're after, thejck.
    You'll find (and HAVE found) staunch opponents and proponents to subs with SRS's
    It comes down to application and personal taste. A sub will add appropriate weight to music and offer a much more reinforced sub-bass frequency response. Likely, someone will come in and argue that recoding studios filter out this information anyways except in the occasional classical/chamber/organ recording, but according to a personal friend who is a producer in Nashville, this is rarely ever the case, and just not that clear-cut.
    There are those, too, that will say you don't need a sub because they've been to such and such audio show with hundreds of thousands in gear and none of them had subs, so subs must not be necessary. As I'm sure you can tell it's a logical fallacy. Specifically a hasty generalization. The truth is that MOST high/very-high end speakers are designed as a system with separate stereo subwoofers. But the implementation is based on the end user. It's easier to upsell someone on a sub from a lower price and the promise of better sound then downsell from a high price and a promise of less full sound.
    Anyways, a sub is a nice addition to a great set of speakers like SRS's but requires as much forethought and planning/experimentation as does any other part of the audio chain, often more-so. You can't just add a $400 sub, throw it in the room and expect a cohesive sound.
    My suggestion:
    stereo subs of equal quality to the SRS's and a preamp with dual outs. Although the last part is mostly an ideal situation.
  • PolkClyde
    PolkClyde Posts: 662
    edited April 2011
    thejck wrote: »
    I have the Polk 1.2's and enjoy my PSW 505 Sub.try both setup,HT and 2 channel and make your own decision.don't let or allow anyone to tell you what sounds good to you.I like both set up in my rig.... PSW 505 Rules.it may not be the best,but it is for me at the moment.
    PolkAudioClyde
  • analog97
    analog97 Posts: 328
    edited April 2011
    When I first got my 1.2 TL's, I thought they were a little bass shy, but numerous equipment upgrades proved that to be absolutely false. I have not used my sub in years and this sub is the big Paradigm Reference 15. Truly, it adds little in my 26 X 20 room, unless you want to turn it up and rattle walls. But, I prefer the bass to be flat (db-wise) and not boomy for music. I am going to look for a new home for my sub.
  • thejck
    thejck Posts: 849
    edited April 2011
    I have a good amplifer and have done quite a few of the tweaks for the speakers so far.
    I am currently working on some room upgrades. I have 5 x 6foot windows that sit behind me. I am trying to figure out a way to kill the reflections of these windows.
    I guess after that is done I need to add a sub and see if I like it better.
    edited April 2011
    What amp are you running and what tweaks have you done? Source? Cables?
  • OldmanSRS
    OldmanSRS Posts: 419
    edited April 2011
    If you are considering a sub, it HAS to be a good one or you will degrade the sound of the SRS. Room accoustics, standing waves at low bass frequecies, all play into the decision to sub or not. I run an HSU VTF3 sub crossed over at 25 Hz and just barely on. It adds the extra depth at low and mid volume levels that brings the deepest bass from pipe organs, standup basses, kick drums etc, to tight, impressive reproduction. It's not the least bit boomy and integrates well into the SRS's.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • thejck
    thejck Posts: 849
    edited April 2011
    heiney9 wrote: »
    I have a parasound hca-3500 amp. that puts out 350 watts/channel at 8 ohms.
    Using some canare star quad cables that I made myself
    1. Larrys rings
    2. Mortite
    3. Dynamat
    4. Croossovers were TL's by Ben with sonic caps on the upper end.
    5. spikes
    6. rdo 198's
    I plan to do the new gimpod's boards and new inductors soon and replace all caps with sonic.
    My source is lossless flac played out off a pc using an optical cable to an external dac. Parasound p3 2 channel preamp.
    I play my music using foobar with the wasapi plugin to enable bit-perfect playback.
  • newrival
    edited April 2011
    thejck wrote: »
    1. Larrys rings
    2. Mortite
    3. Dynamat
    5. spikes
    6. rdo 198's
    Well I'd say you've handily cut off anyone blaming it on the lack of mods to your srs's :biggrin:
    Are you able to borrow q good sub from anyone? If not many highend sub makers give you a risk free trial period. If you do it, I'd love to hear a review :)
  • thejck
    thejck Posts: 849
    edited April 2011
    due to my preamp being 2 channel only I dont have any crossover mangement for the sub. The preamp has balanced and unbalanced outputs. I am currently using unbalanced to the amp. I guess i would have to run the balanced outputs from the pre to the sub. I am not sure if they are both functional at the same time.
    I guess on the sub I can use the low-pass crossover to make sure its only reproducing those Hz's down low but I wont be able to cut off those lower Hz's to the main speakers.
    Would that be a problem?
  • OldmanSRS
    edited April 2011
    I run the SRS1.2s at full frequency and suplement them at 25 Hz and lower using the 24 db/octave low pass in the sub. Sub placement and phasing are critical to seamless integration of the bass.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
    edited April 2011
    thejck wrote: »
    I don't believe you can run both single ended and balanced connections simultaneously unless they are two completely seperate outputs as labeled like "output 1 and output 2". Most use Y adapters to split the signal coming from one or the other. Single ended would be easier and most prevelant if you decide to do it that way. Kind of a "make shift" way to do it.
  • thejck
    thejck Posts: 849
    edited April 2011
    when you run y adapters dont you get some loss of signal (dB)?
  • OldmanSRS
    edited May 2011
    Theoretically, yes depending on your preamps output impedance. You are driving twice the load (1/2 the impedance) but in the rearl world you probably won't notice it. Most preamps have a much lower output impedance then most amps input impedance so they can drive the parallel load just fine.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
