Help me choose, please!
jhumur
jhumur Posts: 33
edited April 2011 in Speakers
Ok, I am convinced now that I need a Center Channel Speaker, and ready to make the The question is which one? My current setup is a pair of Monitor 70 Series II (in one of my earlier posts, I erroneously said Monitor 60) and a PSW10. So, which Center Channel speaker should I get? Here's the Newegg lineup (they're having great PROMOS on a couple of these) :
CS1 Series II (Cherry).......$90
CS10 SeriesII (Cherry)......$90
CS2 Series II (Cherry)......$105
CS20 Series II (Cherry).....$150
At those prices, the CS2 seems like the obviously choice. What I am debating is whether the additional $45 for the CS20 is worth it. I am let to believe that the differences between CS2 and CS20 are merely cosmetic. What do you think?
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    When I was using my monitor 70,s as front speakers, I used a CSIA4 as a center. Dialouge in movies is so important I wanted a very clear center, just something to consider. $179.95 on polk direct currently.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited April 2011
    The CS2 and CS1 are matched to the Monitor line. If you have room for it then go for the CS2. I haven't heard the CS1, but bigger has got to be better here. I have the CS2 and it works perfectly with the Monitor 70's. it got even better with more power put to it. Everything seemed to get a bit clearer IMO. Thats a good price too!
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • jhumur
    jhumur Posts: 33
    edited April 2011
    Thanks, Rodeo0530, for the insight.
    slk55amg, speaking of matching, would the CSIA4 match my 70s? Would I be able to balance the CSIA4 against the 70s?
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    Its NOT an exact match. The RTIA line is the next line up from the Monitors. It worked great for me when I used it, very satisfied with the results.
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    edited April 2011
    slk55amg wrote: »
    Right, it certainly couldn't hurt upgrading the center. I doubt the mains would suffer from it. It would be the other way around if you upgraded the mains and not the center.
    As far as the egg list, definitely the CS2 over the CS1. I had a chance to demo them side by side and what a difference. The CS1 is a great speaker, but when listened to side by side, the CS2 makes the CS1 sound like it struggles to keep up.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited April 2011
    The matching question aside, I'd wonder how the CSiA4 would keep up with the 70's. My thinking is the 70's are the biggest speaker in the Monitor line. The CSiA4 is the smaller center in the RTi line. I'd think if you were going to do an upgrade to the center you might want to go to the CSiA6?
    Full disclosure, I run the 70's with the CS2 and am very happy with it. I do have different EQ profiles for movies (center slightly quieter) and TV (center slightly louder) to make sure I don't miss dialogue even if the sound engineering on some TV shows isn't stellar.
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    The CSIA6 would be overkill with 70,s the CSIA4 worked great.
  • jhumur
    jhumur Posts: 33
    edited April 2011
    Thanks, guys! I think I'll pick up the CS2 soon; unless I find a killer deal on the CSI-A4
  • Rodeo0530
    edited April 2011
    You'll be plenty happy with the CS2...have fun getting everything up and running!
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
