MIT Terminator 2 Speaker Cables
renowilliams
renowilliams Posts: 920
I just purchased a set of these cables used. My first impression is that the sound is a bit more laid back as well as a slight bit more base extention. I'm not sure whether the sound change has something to do with the new Oppo 93 I bought at the same time.
What I am wondering,is what are the boxes in the cable for?
Tim
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • gfong
    gfong Posts: 1,079
    edited April 2011
    What is the benefit with Multi-Pole technology?
    Multipole technology is like having the performance of many cables rolled into one. Simply put, any cable, network or filter will have measurable components of inductance, resistance, and capacitance. The different combinations, or values of those components create a point of magnitude (Pole), somewhere within the audio range. Every cable will have one measurable, and definable pole that will define the articulation range for transferring the music. When comparing this articulation pole from manufacturer to manufacturer, it will usually be centered at different frequencies. The placement of this articulation pole is the main reason we hear differences in cables. Let’s say you had a cable that sounded great in the bass frequencies, and then a cable that did very well in the mid-range, and yet another that was very good at transporting the higher frequencies, and you bundled them all together to make one cable. In theory, you would have built a “three pole-MultiPole- audio cable.”
    MIT Multipole technology is our patented solution for allowing all of the frequencies, and all of the music from your recordings to be heard without either emphasizing or de-emphasizing any of the music. For reference purposes, various MIT Multi-pole technology levels can ascertained on all of our products. This is signified by a number and an X. For example. our AVt Level 1 RCA interconnects have a logo that reads “5X”. This means that this product has five times the performance of just cable, so when you see these numbers on our packaging you will know instantly what level of performance that you are looking at. Multi-pole technology will deliver better bass, clearer mid-range and more articulate high frequencies when used in any audio system.
    (Copied from MIT FAQ's)
    It is explained on their home page.
    http://ww2.mitcables.com/
  • renowilliams
    edited April 2011
    lol...ya I went there. Guess I should have looked to begin with.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    F1nut Posts: 52,406
    edited April 2011
    FYI Tim, it's bass.
  • headrott
    headrott Posts: 5,496
    edited April 2011
    FYI Tim, it's bass.
    Jesse, I thought that was a fish?:confused::tongue:
    Greg
    P.S. Oh I get it now...... there's bass(the fish), bass(the low end of the audio spectrum) and base(the lowest point on something).:biggrin::wink::tongue:
    Greg
    F1nut Posts: 52,406
    edited April 2011
    Yeah, it's all so confusing. :wink:
    This one is a pet peeve of mine.
  • renowilliams
    edited April 2011
    So bassically F1, your saying I should get this right?....lol
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
    F1nut Posts: 52,406
    edited April 2011
    Very good, sir. :biggrin:
    To answer your original question, they make the music mo' better.
