RD0194 Tweeter polarity in RTA12C
Crashdot
Crashdot Posts: 182
edited July 2011 in Vintage Speakers
Greetings,
I am changing out the crossovers in my RTA12C's and noticed that the tweeters were not consistently wired, which may have been an error while reassembling after initial testing. I would like to know which wire goes to the red marked terminal on the RD0194 tweeter.
Sorry if this has been discussed before, but I've seen contradicting posts.
The wires are:
Black: HF GND OUT
White: HF OUT
Post edited by Crashdot on
  • drumminman
    drumminman Posts: 3,396
    edited April 2011
    On mine, I believe black goes to positive and white to negative or ground. I'll have to look when I get home.
    I recently completed rebuilding both the upper and lower xovers, and the color of the wires was consistent in terms of polarity.
    I'm thinking about the RDO194's as well, but I'm waiting to see what effect the xover upgrade has once everything is burned in.
    FYI I immediately noticed a richer, smoother 3D sound. Also, I realize I'm in the minority, but I don't hear the harshness out of the SL1000 tweeters that so many others complain about.
  • intangible
    intangible Posts: 262
    edited April 2011
    The red post gets the hot wire, so you want to connect the white one to it.
  • cincycat13
    cincycat13 Posts: 887
    edited April 2011
    intangible wrote: »
    Plus 1 vote
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited April 2011
    Did Polk go back and forth on the color coding of their hookup wires for different models? Other Polk models I've been in use the black wire for hot and white for ground.
  • TennMan
    TennMan Posts: 1,266
    edited April 2011
    On3s&Z3r0s wrote: »
    I was wondering the same thing. I know this thread is about RTA12c speakers but I thought all Polks would use the same wire colors for + and - connections.
    The black wire was connected to the + terminal on the sl2000 tweeter in my Monitor 10Bs when I got them. I replaced the sl2000 with RDO-194s and connected the black wire to the red terminal on the RDO-194s. Isn't that the way they should be connected?
  • On3s&Z3r0s
    edited April 2011
    TennMan wrote: »
    Yep. It's true that the positive lead from the crossover should connect to the positive terminal (marked with a + or colored red) on the tweeter. In the 5Jr and SDA 2B black is used for the positive on tweeter and MW. Other colors were occasionally used (like for the dimensionals in the SDAs) but I don't know why they wouldn't be consistent with the black and white for the models with a single tweeter.
  • DaveHo
    DaveHo Posts: 3,536
    edited April 2011
    The RTA12's are a bit different than other Polks. The negative, white, wire does indeed go to the positive terminal on the tweeter. I believe this is due to the phase being inverted somewhere in it's complex xover. See the wiring diagram here: http://www.polkaudio.com/forums/attachment.php?attachmentid=18713&d=1155781986
    -Dave
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2011
    DaveHo is right. The white wire goes to the positive side of the tweeter.
  • Crashdot
    Crashdot Posts: 182
    edited April 2011
    I'm not sure why none of these tweeters (SL2000, RDO194) seems to have a + sign anywhere to be seen; am I missing something?
    So just to be clear, you are saying:
    Black: HF GND OUT connects to silver (untinted) terminal on tweeter
    White: HF OUT connects to red terminal on tweeter
  • On3s&Z3r0s
    edited April 2011
    The SL2000 probably has a plus molded (not very visibly) on the plastic baffle near one of the terminals. It might be under the foam gasket if that came off with the tweeter. You want that foam behind the new RD tweeter by the way. On the RD tweeters they just made the terminal red with no other indication from what I've seen. Thanks to Dave posting the link to the wiring diagram, I agree with everybody else that white connects to positive/red and black to the untinted terminal.
    That is one wacky XO! (Actually, they all look pretty wacky to me, just more used to looking at the SDA ones.)
  • drumminman
    edited April 2011
    DaveHo wrote: »
    -Dave
    I looked at how mine are wired and the white goes to the positive, the black to negative. The black is definitely positive throughout the rest of the wiring, but coming off the Xover to the tweeter it's labelled "HF ground out." :rolleyes:
  • Joe08867
    edited April 2011
    Is it bad when an SDA crossover makes more sense than the RTA line.
  • renowilliams
    renowilliams Posts: 920
    edited April 2011
    Just curious....what would happen if you wires the rdo-194 backwards? would it work or not?
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • On3s&Z3r0s
    edited April 2011
    Do you remember the scene where they cross the streams in Ghostbusters? Probably nothing worse than that. :wink:
  • renowilliams
    edited April 2011
    lol....well I guess mine are right....they sure sound much better,which I'll take as a good sign.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • On3s&Z3r0s
    edited April 2011
    :biggrin: Obviously, I don't know the real answer to the question, but I'm 99% sure that in the case of the 2A's you should be black to positive and white to negative.
    I think there would be a difference, but only because when I was soldering leads onto my RD0-198's they buzzed when soldering the ground but not the hot terminal. Weird.
  • Crashdot
    Crashdot Posts: 182
    edited April 2011
    Since one of mine was wired in reverse, I can tell you that it does work, but my understanding is that it would not be in proper phase and may therefore cancel out frequencies from the other tweeter.
  • Joe08867
    edited April 2011
    Crashdot wrote: »
    Bingo, give that man a prize.
  • Davesworld
    Davesworld Posts: 8
    edited July 2011
    I see a lot of misinformation here about tweeter polarity. In the RTA12B or C, the tweeter polarity is reversed. HF+ out does NOT go to the red terminal! It goes to negative! The wiring diagram reflects this as well. You're dealing with a recessed tweeter crossed at 24db per octave. The crossover throws it 360 degrees out of phase meaning that it's a full cycle behind. The combo of crossover phase, tweeter polarity and recessed top mounting is all part of the phasing of the entire system. Wire them with + to + and - to - and you'll create a undesirable though not dire audible effects.
  • FTGV
    FTGV Posts: 3,649
    edited July 2011
    Davesworld wrote: »
    Correct and the resulting frequency response would show a null or suckout around the crossover frequency atleast on the designed listening axis.
  • Crashdot
    Crashdot Posts: 182
    edited July 2011
    Clearly there is considerable disagreement on this, so how can I confirm which is correct?
  • FTGV
    FTGV Posts: 3,649
    edited July 2011
    Crashdot wrote: »
    I don't see the schematic for the 12C but the one for the 12B indicates the tweeter is connected in reverse polarity.
  • drumminman
    edited July 2011
    The only difference in the later RTA schematics appears to be the use of a polyswitch in lieu of a 3/4 amp fuse.
    When I rebuilt my upper and lower crossovers I compared what was in front of me with the schematic for the 12B.
    The tweeters are definitely wired out of phase. :wink:
  • Joe08867
    edited July 2011
    Like Drumminman said they are wired out of phase.
    It has been discussed and even checked by several of the CP fellows.
  • drumminman
    edited July 2011
    drumminman wrote: »
    Wire your tweeters with black to + and white to -. Listen to some music you know well. Then reverse the wiring.
    Reverse phase yields an amazingly smooth, deep, 3D soundstage. :cool: In phase should sound pretty wonky. :tongue:
  • Davesworld
    Davesworld Posts: 8
    edited July 2011
    FTGV wrote: »
    Correct and the resulting frequency response would show a null or suckout around the crossover frequency at least on the designed listening axis.
    I figured there would be a suckout. I'm also sure that a lot of people have their RTA's wired wrong too at this point.
  • FTGV
    FTGV Posts: 3,649
    edited July 2011
    Davesworld wrote: »
    Yes theres likely a few that have been tinkered(tampered) with without the benifit of consulting the schematic.
    btw.welcome Dave.
  • Davesworld
    Davesworld Posts: 8
    edited July 2011
    Thanks! Still got my early 12C's from 1983.
  • Crashdot
    Crashdot Posts: 182
    edited July 2011
    Davesworld wrote: »
    After looking over the PCB and schematics to the best of my abilities, I have to agree. I opened up the HFM and took a photo for comparison to the pcb and schematic images, and it does appear that the HF OUT white tweeter wire is intended to go to the tweeter's negative terminal.
    I have attached a composite drawing with the overlayed a photo of the flipped version of the underside of the PCB with the PCB diagram and schematic for consideration.
    To summarize:
    HF OUT white wire = Tweeter Negative (-) aka Silver Terminal
    HF GND OUT black wire = Tweeter Positive (+) aka Red Terminal
    Concur?
  • Hamatym
    Hamatym Posts: 269
    edited July 2011
    So confusing!....Looked at my 12C's I picked up awhile back and one speaker had the white wire going to the red "positive" terminal on the RDO194 and the other speaker had it going to the negative. Obviously they were not the same, but after reading this entire thread I do not know which one was correct...sound wise was pretty close going from left to right, but I know they are meant to work together.
    I ended up going with the White wire to the red "positive" terminal on the RDO for both and they sound great. It may be backwards or correct....who knows anymore...ha ha
