upgrading my ICs
leftwinger57
Hi guys , I am starting to take alot of advice from some of you forumites and it has proven a smart move.
My next attempt at some audio improvement will be to change out my mix bag of Phillips and no name I-Cs to some 6ft Pythons I saw at CNA for very reasonable prices. I still cannot afford most of the cords you guys are talking about so another opinion I could use. Do you think these Pythons will make a difference and let my tell you ,I'll be one stubborn convert.
Remember I was the one who bought into Rodger Russels' theory on wire hook line and sinker as they say I got pretty much blasted for that. So opening my eyes and seeing what these ICs go for on Audiogon there has got to be something to it.Keep in mind I cannot afford more than what I intend on getting,I also need some other fittings to get for my computer h/u.
Thanks, oh I did check out monoprice and liked CNA for what ever reason this is the place I'll go with.......LW
One other small thing I have a conversion chart right here and 1 meter is just a little to small ....
If those are the Pythons I'm thinking of, I don't see how replacing a cheap cable with another cheap cable will give you much benefit. I would suggest you save your coin and wait untill something pops FS here. Did you not pay attention to the 50 buck MIT's thread ? Doesn't get much better than that bro.HT SYSTEM-
lsi 9's -
If you want to experience a good cable without spending a ton of money I suggest Blue Jean Cables or Signal Cables. I have both, along with IXOS interconnects, and I prefer the build of the Blue Jean Cables.
Some other budget cables that perform:
Kimber Tonik/PBJ
AQ Sidewinder/Copperhead (handle with care/solid conductors)Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
JHC, how many times are you going to post mutiple threads on the same subject!!!! I am so done answering your questions.
While he may post repetitive posts, give him a break! He did cut loose from the RR dogma and that in itself is worth several passes in my opinion:biggrin: A guy willing to at least try and throw off past beliefs may be a bit antsy and have a bit of doubt. My soap box talk is now done:redface:
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
To be fair to the op tonyb those MIT's on sale were speaker cables only -
I just got a nice pair of AQ IC's (should arrive 4/21) on here for $60. Just gotta keep your eyes open (aka.. be faster than me. lol)65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Gordon
Ok Gordon, I'll lighten up. I just get tired of the repetition and his thought process is hard to follow when it's all over in various threads of the same type.
I agree completely! I just thought if the guy is willing to open his mind a bit, we should give him a bit of room to voice his concern and probable apprehension. He may go back to it, but at least he's trying. No foul!!
Gordon2 Channel -
I did forget to mention that I did call Blue Jean Cables and were very nice onthe phone.
What they said to me yes there is a difference (duh) but you need not spend thousands
on a set of ICs.They make theirs by the order and for me a 1.2 meter or 4ft would be $ 39.00 plus shipping. Now this seems resonable using Belden which I use for various things when I installed electronic security systems...LW2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
