Amp to amp
bsoko2
bsoko2 Posts: 1,449
edited April 2011 in Speakers
I feed a RT 1000p tower with 405 wpc Carver Grand Cinema amp (upper posts) and it has a built in amp rated at 70 watts (sub, lower posts). The binding posts are strapped with the tower amp plugged in. The audio signal comes in and goes to both sets of posts. The sub is being feed the 405 wpc and going thru the amp. Is the tower amp amplifing the audio with 405 watts audio? Or is the tower amp not having any effect on the 405 wpc audio thru the subwoofer? I have the gain on that tower amp at halfway (12 o'clock on the gain).
Thanx, Bill
Post edited by bsoko2 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited April 2011
    Kind of weird the way you phrased that but let's see if I can answer you.
    No matter what the current/wattage that the lower set of binding posts receive, your built-in subwoofer will only see what the built-in amplifier is putting out.
    Hook up a 20-watt tube amp or 500-watt solid state amp, the built-in subwoofer won't see a change in power. It could however, see a better/worse signal depending on the cables you're using.
    When I owned RT1000P's, I used interconnects and eliminated the binding post jumpers.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2011
    Not really knowing these speakers, my guess would be, no it is not using any of the power from the Sunfire amp to power the internal subs in your speakers.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • bsoko2
    bsoko2 Posts: 1,449
    edited April 2011
    Thanx guys! Just the answers I was looking for.
  • newrival
    newrival Posts: 2,017
    edited April 2011
    bsoko2 wrote: »
    Thanx, Bill
    Excuse me if you already knew this but it was unclear if you do from your post: An amplifier does not continuously output at it's rated level (in your case, 405W). With your 1000p's being quite efficient its like they NEVER see that much wattage, especially having a powered sub. They probably use 1/4 of that at any given moment at very loud levels.
    tonyb Posts: 33,066
    edited April 2011
    Yep, kinda a waste of an amp there. The top end uses very little wattage all things considered. Maybe it's time to get your feet wet and move up the speaker chain, let that amp strut it's stuff.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited April 2011
    Orrrrrrrrrrrrr, you could let me borrow it Bill. I'm just above you in Tacoma.:smile:
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • bsoko2
    bsoko2 Posts: 1,449
    edited April 2011
    tonyb wrote: »
    Actually, I got the Carver Cinema amp for my mains and center. Polk SDA SRS 2.3TL's with rebuilt crossovers (Sonicraft caps and resistors) and Polk CS1000p. Did I get my feet wet enough?
  • bsoko2
    bsoko2 Posts: 1,449
    edited April 2011
    Geoff4rfc wrote: »
    you would probably like to borrow my quad Empires too?
