Side positions
acdds
acdds Posts: 253
Should I place the side surrounds in front of the listening position or behind the listening position? I have 7.1 w/ 2 rear surrounds. Currently, I have the side surrounds about 1.5ft in front of and 4ft to the side of the listening position. My rear surrounds are 4ft behind and 3ft to the left and right of the listening position. Any thoughts? I'd like to know where other people have their speakers set up w/ 7.1. Thanks!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2003
    WWW.Dolby.Com has some really great info on placement. I think you'll find that 2-3' above ear level, and slightly behind the primary listening position will give you great results.
  • acdds
    acdds Posts: 253
    edited August 2003
    If I put my side surround slightly behind the listening position then my rear and sides will be about 1.5 ft apart. Is that too close? That doesn't seem like it would give a nice even sound field.
    DVD = Denon DV-2900
    (Carver m1.5t)
    Center = CSi40
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Rti38's
  • Frank Z
    edited August 2003
    Well trying to get perfect placement can be a real chore and is rarely achieved. How far apart are the rear speakers from each other? Any chance you can move them a little closer together?
  • acdds
    acdds Posts: 253
    edited August 2003
    They are about 8 ft. apart. There is a double door that opens to a balcony so I can't put them any closer together and still be able to open the doors
    DVD = Denon DV-2900
    (Carver m1.5t)
    Center = CSi40
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Rti38's
  • Frank Z
    edited August 2003
    Hmmmm, tough choice! how about using a couple of step ladders as temporary stand and try them directly to the side of your listening position, and then slightly behind. Make sure you calibrate each time you move them and reset the speaker distances via your receiver if you have that option.
    BTW Are you using direct radiating speakers on the sides or Bi-pole/Di-pole speakers?
  • acdds
    acdds Posts: 253
    edited August 2003
    I am using Fxi50's as sides. They are on speaker stands that place them at ear level. My rears are Rti38's on the same type of speaker stands. The rest on my set-up: Front = Rti70's (biwired)
    Center = Csi40 (biwired), Denon 2803, and a Sony 12" sub.
    The Fxi50's are set to Bipole.
    DVD = Denon DV-2900
    (Carver m1.5t)
    Center = CSi40
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Rti38's
  • Frank Z
    edited August 2003
    Piece of cake! since they are already on stands, move 'em around, re-calibrate after each move and listen. find the spot that suits your tastes and leave them there!
