MYESound spikes on the way!
BuckeyeTim
BuckeyeTim Posts: 483
edited April 2011 in Speakers
Had an email convo with Grant from Myesound and finally ordered a set of spikes for my SDA's. Should be here shortly as they are coming via airmail. I'm doing the happy dance!
Post edited by BuckeyeTim on
  • janmike
    janmike Posts: 6,146
    edited April 2011
    Congrats. Grant makes great stuff.
    Michael ;)
    NORTH of 60°
  • inspiredsports
    inspiredsports Posts: 5,501
    edited April 2011
    post #3 dienalsmith44 spam reported
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    Toolfan66 Posts: 17,340
    edited April 2011
    You will be saying to yourself "why did I wait so long to get these??" They are one of the best tweeks for your speakers IMHO..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • thsmith
    thsmith Posts: 6,082
    edited April 2011
    I have the same spikes on my 1Cs and as TFLF says they are a great tweek.
    Congrats!
  • nspindel
    nspindel Posts: 5,343
    edited April 2011
    And I have TOOLFORLIFEFAN's spikes on my 1C's, they're great too!:wink:
  • packetjones
    packetjones Posts: 1,059
    edited April 2011
    Not trying to thread jack here but curious how these are different than say the standard spikes that came with my speakers?
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
    F1nut Posts: 50,769
    edited April 2011
    Mye Sound spikes are made from solid brass billet, not steel like the stock ones. Brass has long been the preferred choice for spikes.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited April 2011
    I wish i could replace the ones on my lsi's.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • george daniel
    george daniel Posts: 12,096
    edited April 2011
    Yep-- and it's soft too-- meaning that you cannot move em very much--hell,,what I'm trying to say is that they will bend easily,,I know cause I bent two--don't ask.Congrats--.
  • BuckeyeTim
    edited April 2011
    I'm hoping I like them half as much as everyone says I will.
    I thought about getting a set the day I picked up the 1C's, but decided to wait. If I did every single upgrade at once, even before I have had a chance to audition them as is...I wouldn't appreciate each individual tweak for what they are. It helps to understand why you all make certain tweaks and adjustments.
    I started to make my own set at work. I started with long shank bolts. I cut the heads off and turned down the shanks to a sharp point. They came out so sharp with the 8 degree angle I chose that I thought the SDA's would push them half way through the subfloor. Figured for the price, I might as well just order a set and be done with it.
    Tim
  • BuckeyeTim
    edited April 2011
    The spikes arrived yesterday all safe and sound. Very nice looking pieces! Unfortunately, they will have to wait until the weekend for an install. I don't think the wife unit would appreciate a 2am test session.
  • erniejade
    erniejade Posts: 6,321
    edited April 2011
    I noticed the bass got tighter when I put my MYE spikes on. Nice choice!!
  • vc69
    vc69 Posts: 2,500
    edited April 2011
    erniejade wrote: »
    Ditto. Spike and pads here. Well spent money.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
