Rt-3000P repairs?
civilian
civilian Posts: 357
edited September 2012 in Vintage Speakers
I am thinking of picking up some 3000's locally that are in really bad shape and won't have the opportunity to test them before purchase.. I would like to re finish the wood and grills which will be no problem.
I think I have heard (read on here) that replacement parts are fairly hard to come by? Is the Amp and Crossover one unit on these?
Thanks in advance,
________________
2 Channel-Denon AVR-4520/SDA 2.3TL's
5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
Post edited by civilian on
  • cincycat13
    cincycat13 Posts: 887
    edited April 2011
    Yes the parts can be hard to come by. I believe newrival repaired a set recently so you can check with him about his experience. The sub drivers are not available from polk and I don't think the amps are either.
    The sub XO may be on the amp. The binding posts are on the plate, but my wife moved my spare so I can't find it to check. The top XO is independant.
    At least plug them in to see if the amps buzz and make sure the sub drivers aren't frozen. For the right price you could probably get them and part out if all else fails.
    good luck!
  • newrival
    newrival Posts: 2,017
    edited April 2011
    yep, the xover is mounted on the plate amp. I'll comment more after I get out of the office.
  • newrival
    edited April 2011
    sorry things got crazy and forgot about the thread. oops
    Anyways, does the seller make any claims to their operational condition?
    I spent a lot of time tracking down parts. And when they come by, they aren't cheap. You can try and send the amps into Polk if they need some work, and they may be able to fix any ailments. If not, the amps originally went for ~$750/each and arent cheap when they come around now.
    I had almost given up on finding a replacement driver and had settled on replacing all 4 with something similar. The problem with th MW8500 sub drivers is there is almost no information on them. No designers notes at the company, no diagrams, nothing. What I was able to find out while researching was that they were 4-ohm and 86db/1m/1w. Although this doesn't give you much it does help find a suitable replacement. Aditionally I roughly calculated the box volume and between this and measuring the port length, i came up with a few drivers that would fit the bill. So this being said, you could easily purchase replacements.
    The drivers for the monitors are much more readily available being used in a number of models such as the CS400, RT55, RT800, RT1000, etc...
    Also, If you get these for a pretty great price, i'm sure you could part these out quite easily and make your money back.
    VR3 Posts: 28,784
    edited April 2011
    You guys can send me a woofer and I can get any info you want on them!
  • civilian
    civilian Posts: 357
    edited April 2011
    newrival wrote: »
    I made a little run at them but came up short.
    The seller never responded to any of my questions about the amps and we are in the middle of a major (10 year) spring cleaning where I am trying to get the wife to get rid of a lot of stuff and consolidate her girl-scout supplies.
    Can you tell us who was assembling that day ;)
    What all can you find out?
    ________________
  • dpowell
    dpowell Posts: 3,068
    edited April 2011
    I know a guy local who can repair anything as long as he has a schematic. He replaced the caps on a RT3000 amp for me about a year go. Caps were $16ea. from Polk. If the rest of the speakers are salvageable and you're willing to make the trip to San Marcos, he'll do the repairs very reasonable. I think he charged me $30 or $40 for the work.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • civilian
    civilian Posts: 357
    edited April 2011
    Heres a pic and a link to the ended auction, I am sure more will come along at a better time.
    ________________
  • cincycat13
    edited April 2011
    dang, i considered mine as rough...those definately move mine up to presentable. Post the link if you get a chance. You got me curious.
  • newrival
    edited April 2011
    click on the pic, cincy. It takes you to the auction.
    I would totally buy those for the money they went for. I wish it wasnt a private bidder, i'd see if i could get some parts.
    spares are nice to have :D
    VR3 Posts: 28,784
    edited April 2011
    I just recently purchased software that can tell you ts parameters - really anything you want to know
  • bsoko2
    bsoko2 Posts: 1,449
    Got my rt3000p amp back today from Polk and it works. I had sent it in last Dec., 2012 and was told that it was good to go and when I played it, it still didn't work. Sent it back last month and Art at Polk Tech (Vista, Calif) said that he would check it out for me. Well he did and replaced 3 items on the board and it now works most excellent. This gives me 2 sets of 3000p's now.
  • cincycat13
    That's good news. I just sent 3 amps to CA last week. I was kind of hoping FED ex lost them for what Polk told me to insure them for. I could probably make more money parting out 4 amps than selling my RT5000p set up...Hopefully my repairs will go as well as yours.
  • bsoko2
    bsoko2 Posts: 1,449
    cincycat13 wrote: »
    Art Martinez is the tech who works on the amps and he gets them working. If it is fixable, Art will fix it.
