why this delay
leftwinger57
Hi guys, I've been dealing w/ this problem for a long time and there has got to be a reason for this. When changing channels on my Tosiba au 37 it some times takes forever for the new station to come up, and on some occasions it doen't change at all. Personally I think it's all through the HDMI cable box
because I do not have this problem w/ my bdm tv. I use Cablevision as my supplier and I've had all sorts of problems that you see exactly on the Vios
commercial.I have had this delay,depixselation ,staggering, and not changing.
I think I'm answering my own question here thining it's all cablevisions tranmitting system.Just wondering if any body else has had these problems.Were talking central N.J. Thanks....LW
H/T---Tosiba au 37>Yamaha RX-V665>Yamaha ysd-11 dock>Klipsch H/T500
W/8in pwd sub >Denon 1940ci cdp>sa4250 cable box hd
2-chl---Adcom gfa555>Onkyo p301 pre>Denon 1940ci cdp >InfinitySM112 s
Shure Pro240 headphones> Samson power plug.
The cable box doesn't like it when you use HDMI through an AVR.. mine does it a little bit too (I have an HDMI from my cablebox/DVR to my Pio SC-25, then to my TV). Has something to do with the anti-pirating software in the HDMI cable..
Once my cable box actually stopped the digital video signal through the HDMI (I could still get sound). And nothing I did worked until I called Comcast and they told me I "couldn't" use HDMI through an AVR since that would set off the anti-copying software.
I just asked them to "reset" my cablebox and it has worked fine ever since... but I'm betting its the cablebox/AVR HDMI issue
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Jason
+1. I have cablevision and experienced the same frustrating problems. When I upgraded to the DVR box everything's much quicker with less issues. I think there's a better processor in that box. The only problem I have now is every once in a while when I get up off the couch the picture and sound go out for a few secs. Weird.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
I wounder is this is a side effect of pre-buffering the channel to support start over features as well as possible on-demand functionality.
It is very frustrating, my cable provider added some on demand channels in the middle of regular channels and whenever I hit these extra -pay on demand I think the delay is because the channel is possible checking the server to see if the customer has the subcription. so it takes a while to re-gain control so that you can move to the next channel.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire
