Upgrade ??
I have the TSI300 for the front with a cs20 center.Also have the psw110 sub.
Running OHM3 in the back.
The system sounds good but naturally I would like better.
Could I upgrade to the Monitor 70 & use my cs20?
I would move the 300`s to the back.
Or maybe just upgrade to the TSI400 for the front.
I am running a Denon 891 AVR.
Any suggestions would be appreciated.
Post edited by dowop on
I have both Monitor 70's & TSi400's - both sound good. I think the 70's sound a little better, but think the 400's look better... Note that my 70's are not the series II that Newegg is selling.
You'll most likely find 70's for less than the TSi's, so I'd go with those.HT
Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
2-Ch
Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's -
If you're going to spend the time and money to upgrade, I'd upgrade to the RTi/RTi-A line....or perhaps another brand. No point in upgrading within the same series IMO.
Is this primarily an HT system?
I think the weak link in your system is probably the sub. might want to start there.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
Yes,I use this system for HT.
If I upgrade to the RTi I am assuming my CS20 would not be all that great.
I just bought it & I have a like new CS10 sitting in the closet.
I dont really want to sell anything.
I will think about thr RTi`s.
Thanks -
I will think about the RTi`s.
