Better amp for RTi setup?
jchandler3
jchandler3 Posts: 11
edited April 2011 in Electronics
Hello all, hoping I can get some advice. My current setup:
  • - RTi8
  • - RTi4
  • - CSi3
  • - PSW-125
  • - Denon AVR-1910
Now, there isn't anything especially awful about the Denon 1910. It seems to do a fine job. Right now I have the 8s "bi-amped." If my budget is say, $500, would there be a reasonable dedicated amp upgrade out there? Otherwise, I'll just continue to save until I can afford a more substantial difference.
Post edited by jchandler3 on
  • gfong
    gfong Posts: 1,079
    edited April 2011
    I am curious if you have listened to your AVR without bi-amping the front speakers?
  • jchandler3
    edited April 2011
    gfong wrote: »
    I have. I notice a very small improvement. To be honest, I didn't do a lot of A/Bing but there was a definite sign of improved dynamics.
  • B Run
    B Run Posts: 1,888
    edited April 2011
    I didn't think the 1910 had preouts?
    Edit: nope it doesn't have any, so you'll have to upgrade to a receiver with preouts to be able to add an amp.
    Toolfan66 Posts: 18,039
    edited April 2011
    I think it does..
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited April 2011
    I think it does..
    I don't see any. Anyhow, I think by "amp", the OP means he's looking for a better AVR... I think.
  • B Run
    B Run Posts: 1,888
    edited April 2011
    If your talking about a better avr, i'd sell your 1910 used for about $250 on craigslist, add it to your $500 budget and find a used Pioneer Elite SC model with the ICE amps in it. I've seen a few in the $750 range used in good shape. If you want something new and 3D capable i'd check out the latest Onkyo, Pioneer, HK, or Denon and just do some research on it.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    B Run wrote: »
    No preouts.
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    I think it does..
    Denon doesn't have pre-outs until you hit the 3K series.
  • jchandler3
    edited April 2011
    Welp, there's egg on my face. I could have sworn there were preouts but obviously I'm wrong. Would simply stepping up to the Denon 3300 series give me the extra oomph I'm looking for? That would additionally give me preouts for any future splurges.
  • jinjuku
    edited April 2011
    jchandler3 wrote: »
    That depends:
    What is your room size? LXWXH. What is your seating distance? How loud do you like to listen to material? An amp may or not make a difference for you. You will just have to try it.
    The Denon 19XX series is competent but nothing to write home about. You may be fine with a better class of receiver.
    Where do you live? There may be a member close enough to let you try an amp. Regardless of external amp or not I would recommend a receiver with pre-outs just for the flexibility factor. YMMV.
  • jchandler3
    edited April 2011
    Room is 15'(L)x20'(W)x9'(H). Seating distance is about 10'. I typically listen pretty loud, especially for movies.
    I'm thinking a better class receiver should give me a little more power, a little more headroom, and more expandability?
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2011
    Welcome to Club Polk.
    Start out with getting a receiver that has all the bells & whistles that you want it to have & make sure it has preouts. Then save more money and get a 2-7 channel amp of at least 200wpc @ 8ohms. This will ensure that your speakers operate to their full potential at all times.
    You can get more bang for the buck buying a used receiver or amp on Audiogon. But start with the receiver first.
  • jinjuku
    edited April 2011
    jchandler3 wrote: »
    My Room size is similar (just a tad larger at 18X22X9) with a seating distance of 14'. I benefited from an amp in the scenarios where I have the volume at -6:biggrin:
    Try a quality receiver first: Denon 3K series, Yamaha 6XX, Onkyo 7XX, (not sure on Pioneers system for what model #'s typically have pre-outs).
    Find a member local to you if you can that may have a power amp they are willing to let you try.
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    I have two SONY ES receivers a 5300 for my main system & a 3200 for my bedroom, rig. Lots of features flexbility very ample power. Terriffic build quality, and with ES products a 5 year warranty.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • jinjuku
    edited April 2011
    slk55amg wrote: »
    Not familiar with Sony's line up but I understand the ES is supposed to stand toe to toe with any other higher end offering out there.
    Do all the ES series have pre-outs?
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    ES Receivers, all have pre-outs
  • JimAckley
    JimAckley Posts: 1,138
    edited April 2011
    B Run wrote: »
    +1 on this. Granted my room is only 13x15x8, my SC-37 powers 7 LSis without a hitch. I still plan on getting a 2-channel and 5-channel amp
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • jchandler3
    edited April 2011
    Thanks for the help! I'll start looking around for some good used deals.
