RT3000p hook-up option #1
mickeyrx70
mickeyrx70 Posts: 2
The owners manual refers to "flat metal connecting straps" used on the SUBWOOFERS when hooking up my RT3000p's using "option #1". I've never had the flat straps, but use the angled straps on the SATELLITEs and make the connections as otherwise described. Does not using the flat metal straps diminish the speaker's performance somehow?? If it does, can I just use good quality speaker wire to connect these binding posts?? Thanks for any help!!
    pitdogg2 Posts: 27,918
    edited April 2011
    mickeyrx70 wrote: »
    yes you can. Some think that it is actually better to use a short piece of wire and spades to connect the upper and lower binding post.
