tweters
EDUARDO
EDUARDO Posts: 14
Hi all
I am from Panama and I know that same tweter in each speaker is the bast If you have diferent speakers.
In Panam
I JUST KNOW THAT I DON'T KNOW ANYTHING !!!
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2003
    Wow, talk about a brother in a need of a speak-n-spell.
    Cheers,
    Jose Jimenez
  • rs159
    rs159 Posts: 1,027
    edited August 2003
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2003
    Try posting your question in the "Troubleshooting" area. I think you might get the attention of the tech support folks that way.
  • EDUARDO
    EDUARDO Posts: 14
    edited August 2003
    WELL
    I WILL POSRT IT IN TROUBLE...
    YES I WANT TO BUY POLK HIGH FREC. TWETERS TO USE THEM IN MY HOME MADE SPEAKERS.
    EDUARDO AH.
  • Frank Z
    edited August 2003
    I'm not sure exactly which tweeter you are looking for, but you might want to search the web for "Vifa." They manufacure the ring radiator tweeter (4ohm) that is used in the Lsi speakers. they even show up for sale on EBay from time to time. WWW.DIYAudio.com also has some links that might be of interest.
    Good luck with your project!
