Sony SACD Megachanger arrving soon !
begbie
begbie Posts: 630
edited September 2003 in Electronics
I'm sure more models to come but here is the first dvd/sacd megachanger and an sacd-only meagachanger to follow.
Also reviewed in the latest Sound&Vision magazine.
http://www.onecall.com/PID_20535.htm#
Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111
Post edited by begbie on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2003
    It's a shame its not ES class yet, but I like the megachanger idea. It certainly has alot of features in one box, but they are the entry level type.
    The SACD only will most likely be ES class.
  • fireshoes
    fireshoes Posts: 3,167
    edited August 2003
    Since they didn't mention, it's $399 and should come out in September.
  • goingganzo
    goingganzo Posts: 2,793
    edited August 2003
    word of caution
    these will not fit in your audio rack without major modifycation. i had to notch the back of my rack. with is mdfb. and it stickes about 2-3 inches but i would think that i would rather have a sacd/dvd-a and get a dvd changer that just dues dvd.
  • PETERNG
    PETERNG Posts: 918
    edited August 2003
    stay away from changer if you don't want to deal with problems and noises...too many moving parts will introduce nothing but trouble later on. Single tray is always better...cheers
  • begbie
    begbie Posts: 630
    edited August 2003
    Well, knock on wood but my mediocre Sony megachanger has been flawless for 3 years and counting.
    It's been a heaven-sent !! :D
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
  • dorokusai
    edited August 2003
    The noise issue is a generic comment. I would presume that most parties involved with this website, would know about the noise created by multiple moving parts. This issue is inherent with all multi-changers, not just mega changers. I have not heard a "silent" changer in my life.
    Is my new SACD changer noisier than my "vintage" Sony changer? Yes it is, I have no idea why, but I am not disturbed from my Zen meditation, while a disc changes either. :rolleyes: I have heard some pretty quiet changers in my time, and Sony, while not normally one OF them, is not the worst I have heard.
    Size wise, this should be a no brainer. If you thought that a disc changer that held 300-400 discs would be the size of a single tray...you just have no clue. What a useless comment.
    It is a player for the person who wishes to compile everything into a box...that person also is probably not concerned so much with its noise, as its function.
    Do I want one? No...why would I. That does indeed seem silly to me. I can't keep track of 6 discs in my changer, let alone 300.
  • bikezappa
    bikezappa Posts: 2,463
    edited August 2003
    To bad the chager didn't have a DVI output. In order to keep track of your 400 discs, either CD or DVD, type them on paper with numbers. DUH. I don't see the problem. As you add discs write them in with a pencil and later type them in.
    I never thought the noise of the changer was a problem. The problem is finding the box with the disc, opening it and loading it in the player, putting the other disc in a box. The changer can do this faster then I can and I save all this storage space.
    The size of these changers is an issue however. They are big.
    I have two 200 CD changers and one 200 DVD changer with no problems so far for 5 years.
    I wish Sony would make a new ES version of a 400 CD changer.
    Playing random with 400 CD library is a blast.
  • dorokusai
    edited August 2003
    Bikezappa - Glad to hear that another mega-changer fan is happy. They do make a ES version of the mega-changer. The
    CDP-M333ES and CDP-M555ES. Here is a link:
    http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_BrowseCatalog-Start;sid=0n8635v38Tg6iaSl0xkw1NT7fXsiO4K_154=?CategoryName=hav_ESShowcase_ESShop_MultiDiscCDChangers&Dept=hav
    I will get one in the future, its a real convenience.
  • bikezappa
    edited August 2003
    Dorokusai
    I have read that there are some problems with the sony 555es changer. Memory loss and some difficult or inconvenient selection options. Have you heard the sound from one? Any comments? I wish a new es model would be released.
    I don't understand the issues some people have with changers. The CD changers have two basic parts, one the storage/selection part and two the player part. The player part should have a high end option, but it never does. Why???
    You must have saved much space by eliminating the 400 CD plastic boxes. The CD changers also protects the CD's from damage due to resting beer bottles and other items on them. CD's are the most expensive purchase of most systems. 400 CD's cost about $8000.
  • begbie
    begbie Posts: 630
    edited August 2003
    Exactly !!!
    Often times, you can get tired of where you placed a disc and spend more time looking for it while the megachanger can pull it up in an instant.
    Megachangers are not for everyone, it is convience over everything else.
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
    VR3 Posts: 29,435
    edited August 2003
    400 Burnt CD's cost about.......120 dollars......
  • bikezappa
    edited August 2003
    Correct! 400 store bought CD's cost $8000.
  • begbie
    begbie Posts: 630
    edited August 2003
    .... no problem. megachangers can handle all those music tracks ! :cool:
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
    F1nut Posts: 51,783
    edited August 2003
    The real problem with mega changers is the compromise in sound quality. They use cheaper transports, cheaper DAC's, cheaper op amps, cheaper jitter clocks, etc. NO thanks, I'll pass.
  • bikezappa
    edited August 2003
    F1nut
    That's exactly my problem. Why can't they make a quality CD changer with good electronics. The storage and selection part is ok in these changers but the electronics is from a $99 CD player. That is just my opion.
    Is the ES 555 model any better sound wise?
    Has anybody compared both players - cheap sony mega changer to the sony 55ES and found a differance in the sound quality?There would seem to be a new market option here if they sound the same.
    I think the problem is that most people compare the mega changers to the old multiple record turntables. It was very difficult to separate the mechanicals of multiple record stacking and good turntable physics. But this shouldn't be so in a mega CD changer. A good record playing juke box from the 1970's can have a good turntable, arm and cartrige. I know because I put one together. In the mega CD changers, all the mechanicals do is put the CD in a depressed form, just like we do if we have a $1000 CD single player.
    Does anyone know anything about the Denon 5000 mega changer? It cost over $1000 but only stored 100 CDs. It could be connected to slave units of 100 CDs also. It is discontinued however.
    I don't want to sacrifice sound quality for convenience.
    Who does?
    Is there any other options?
    Sorry for the rant.
    F1nut Posts: 51,783
    edited August 2003
    Bikezappa,
    I will assume you are talking about the M555ES Mega Changer which I have not heard. Now, the SACD 555ES 5 spinner is a great player if you can live with that. I think the makers of these units know that audiophiles aren't going to buy a mega changer and therefore don't bother to make a high end unit. Supply and demand.
    VR3 Posts: 29,435
    edited August 2003
    Buy 100 5 disc changers, and link them all together....... :D
  • bikezappa
    edited August 2003
    I can see that vision of 100 CD players all lit up and all playing different CDs at the same time! Sonic nirvana or what. I need many Y adapters however and that may degrade the sound experience somewhat. Sort of like listening to a 100 transister radios all tuned to a different stations put in a heap. Polk transistor radios of course.
    VR3 Posts: 29,435
    edited August 2003
    YEP!
  • dorokusai
    edited August 2003
    The CDP-M333ES or the CDP-M555ES, are about as good as a mega changer will get. When the SACD version actually comes out, it will use the same single DAC that the SCD-555ES uses currently. It won't however use discrete components, so the inside will be more basic than the higher end players.
  • begbie
    begbie Posts: 630
    edited August 2003
    Convience , Convience , Convience, that's the #1 reason why people buy mega-changers.
    Outboard DACs will help some of those issues though, but so far there looks to be no perfect cd player for everyone's taste.
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
    VR3 Posts: 29,435
    edited August 2003
    I'd love to have a 400 cd changer...most have a keyboard hook up to list stuff, I use a cheap player now so I won't notice..
    F1nut Posts: 51,783
    edited August 2003
    Perfect player??? Why yes, I own it. The Sony XA777ES SACD player. Does everything well, nothing poorly and plays them one at a time. ;)
  • fireshoes
    edited August 2003
    If you want to hear the noisiest cd changer ever, check out the JVC 7-disc changers. That would definitely bring you out of your acoustic zen whoopie.
  • begbie
    begbie Posts: 630
    edited August 2003
    Sony ES sacd megachanger to come.
    nuff said
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
    VR3 Posts: 29,435
    edited August 2003
    Adcom's complete Analog players are like a bus changing gears after double shifting....very loud they are
  • fireshoes
    edited August 2003
    Hey Trey, if you own any original cd's, I got some homework for you. Make a copy at single speed recording and one at full speed recording, then do a shootout amongst the 3 discs and let us know about any sonic differences. :cool:
    VR3 Posts: 29,435
    edited August 2003
    I own no MP3 based CD's. All CD's I own are either Retail CD's, or Copied CD's of Retail CDs. There are no sonic differences between my CD's. As I own no download based CD's. Yes there is a difference. But from what I do, there is none.
    F1nut Posts: 51,783
    edited August 2003
    "Sony ES sacd megachanger to come."
    Bring it over.....we'll do a shoot out! :D
  • avelanchefan
    avelanchefan Posts: 2,401
    I just bought the Sony 400 disk changer (the 455). So far so good. I like the looks of it despite the hugeness of it. I cannot wait to hook up the keyboard and start entering disk data for each disk!
    The sound is comparable to my five disk changer, but I have yet to give it a really hard workout. I think that will be a while until I get all 200+ cd's in there, and cataloged, and all the disk data put in.
    A job I am actually looking forward to.:D
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
