Power amps
jim 249
Can power amps do weird things with sound or is it they work or don't work? Can they alter the sound to not sound clear or distorted?
Post edited by jim 249 on
yeah, if the power amp has a problem, it can do "weird things".Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Help us to help you. What is it that you are hearing and what type of amplifier do you have?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
The sound is not stable. It varies in volume and tone, really does sound strange. The amp is a Nakamichi PA5-II. I am going to try my Rotel RB970BX. I hope it has the power to drive my 2.3TL's. The cd player was swapped out and still the same. My turntable also will do the same thing. If it is not the power amp than the preamp might be bad.
Sounds like it might be the pre. Switching out the amps will help determine that. It could be something as simple as needing some DeOxit on the controls or RCAs, or it could be something more serious.
t...3 and others can help you diagnose this better as you start experimenting with your set-up.
Hope it's something, simple!
Try the Rotel at lower volumes and get back with us. What you are experiencing is not normal, as if I need to tell you this....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
It may be time for the Nak to be refreshed as well. THat PA5 is a great amp worthy of the cost to restore.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Swapped amps, sound cleared up. Will play for a few days to see if it holds, then will swap back to the Nak5 to see if it comes back. Thanks for the suggestions!
Is the Nakamichi a common ground power amp?
