PSW 125 vs DSW Pro 500?
4WardMotion
4WardMotion Posts: 36
edited April 2011 in Speakers
Well, I just took the leap and purchased myself the RTi A5's for my fronts. After countless hours of research, I felt these would be best for my home. Now it's time to figure out what subwoofer to get.
After doing a little research it's looking like the PSW 125 or the DSW Pro 500 might be what I need. What do you have to say about these two subwoofers and do you think they are the best bang for the buck to go with my RTi A5's?
I would love to get your feedback on this.
Thanks!
4WardMotion
  • dorokusai
    dorokusai Posts: 25,657
    edited April 2011
    Wow, cool choice 4ward :D When are you going to post pics? We have a system showcase here as well, just FYI.
    DSW Pro500, without question. It's built better and hits harder than the PSW125. It is a perfect compliment to your RTiA5.
  • blehmbo
    blehmbo Posts: 179
    edited April 2011
    I've heard both subwoofers, not side by side. I remember the PSW sounding more "boomy." The DSW 500 Pro paired nicely with my A5s. I am happy with it, but sometimes I wonder if I should have saved the extra coin and went for a DSW 600 Pro instead.
  • dorokusai
    edited April 2011
    blehmbo wrote: »
    Blehmbo - I wouldn't lose sleep over it but the DSWPro600 does hit a bit harder, which is a given based on driver compliment alone. Keep in mind that you have one of the best subwoofer lineups Polk has made since 2000 and in that, you made an excellent choice.
    -Mark(Polk CS)
  • SRTer
    SRTer Posts: 372
    edited April 2011
    Thanks!
    4WardMotion
    I have the Polk DSW 500 and 3 Polk PSW-111's. I will tell you that the Polk DSW 500 is much better than anything I have heard in the PSW series.
    The Phase and room correction really works. It has been tested by mags.
    Here is a review. Hope this helps.:redface:
    http://www.soundandvisionmag.com/tests-reviews/speakers/2008/06/polk-audio-rti-series-home-theater-speaker-system
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
