MW7200 for RT600?
tommango
edited April 2011 in Speakers
I have a pair of rt600's with one stuck mid/woofer I also have a MW7200 that was pulled from a RT600i. Would this make a suitable replacement for the mid/woofer in the RT600's?
Thanks for your kind attention.
  • vadang
    edited April 2011
    I am no expert, but I will try to help.
    Simple answer -- yes it will work, but since the drivers are different, they will not be timbre matched. Whether or not you will be able to tell the difference, I honestly do not know. I guess it depends on how picky you are. I know when I needed to replace a driver in one of my RT800i's, it was for the gameroom and I didn't care about timbre matching nor did I want to drop $60 + shipping for gameroom speakers (it was more than I paid for both towers to begin with). So I was willing to put the cheapest thing that would fit correctly be it from an RT800i, RT800, or any of the RT/CS like that uses the same size/cutout driver.
    I'd say use and save money, but that's me. Good luck.
    Living Room:
    Paradigm Cinema 330 x 3, Pioneer 9040TXH
    Media Room:
    RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM
