Speaker mounts for front heights
I just got a pair of monitor 30 that i am going to use for front heights. I was thinking about hanging them from the ceiling. What should i use for mounts?
Thanks!
Thanks!
42 inch LCD LG TV
Receiver - Pioneer VSX-1020
Center - Polk Audio CS2
Fronts - Polk Audio Monitor 70's
Rears - Polk Audio Monitor 40's
Dual Ed A5-350
XBOX360
PS3
Wii
Dual Ed A5-350
XBOX360
PS3
Wii
Post edited by Black96Z on
Thanks!
This is what I used with my R150s for rears until I got my Polk in-walls:
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=6839&seq=1&format=2TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
Had gotten Pinpoint AM-40 and they were nice. I didn't wind up using them decide to use speaker stands instead so i returned them. Had I decided to use a mount these would have been it and would have felt very comfortable using them.
http://www.amazon.com/Pinpoint-Clamping-Bookshelf-Speaker-Mounts/dp/B002UV03MW/ref=sr_1_1?ie=UTF8&s=home-garden&qid=1302272593&sr=8-1
-RobNY -
My height channels are held by B-tech mounts that are very similar to those Pinpoint AM-40s. Works great and angles them down nicely.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Whats your opinion on these? http://www.amazon.com/OMNIMOUNT-Universal-Speaker-Mounting-300CAIFKB/dp/B00009W5X1/ref=reg_hu-rd_add_1_dp
I don't like the way those other mounts look and some of them look like i would have to drill holes is the sides or bottom of the speakers. That is something i dont want to do.42 inch LCD LG TV
Dual Ed A5-350
XBOX360
PS3
Wii -
kuntasensei wrote: »My height channels are held by B-tech mounts that are very similar to those Pinpoint AM-40s. Works great and angles them down nicely.
The BT77 and AM40 are identical. I'm not sure which I have, but they work well. I'd rather spend $60 than $80. They both use the same image on Amazon...
http://www.amazon.com/Rocelco-B-Tech-BT77-Ultragrip-Loudspeaker/dp/B004DCAOHK
http://www.amazon.com/Pinpoint-Clamping-Bookshelf-Speaker-Mounts/dp/B002UV03MW/ref=pd_cp_e_0 -
Mine are actually the older plastic B-tech mounts, but yeah... those two mounts look identical to me.Equipment list:
Emotiva XPA-3 amp
