Auralex 2'x4' Studiofoam panels 12 in all 96 cubic feet
HB27
Indianapolis
I'm selling an extra case I don't need of Aurelex Acoustics panels in blue.
2" Studiofoam Wedges. Unused never mounted or installed.
2 feet X 4 feet panels. 12 panels in the case.
I bought two cases and needed only one.
Very effective room treatment material.
Easily cut and shaped with an electric knife. I used a metal yardstick as a guide for perfect cuts.
This case sold for over $500 asking $250 cash or possible trades on tube gear. OR GUY STUFF.
The colors look weird on these and that's the way both cases were when I bought them.
Pick up preferred in Indy.
http://www.auralex.com/acoustic_studiofoam_2w/acoustic_studiofoam_2w.asp
I have an extra new case of Auralex insulation I'll throw in. http://www.auralex.com/sound_isolation_mfi/sound_isolation_mfi.asp
Post edited by HB27 on
Do you glue them to the wall or do they have some kind of self sticking thing? Would they stick on a cement wall?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
If they dont have adhesive you could just go to Michael's and buy some spray glue to get them to hold on the cement wall (assuming its watertight and wont get water condensing on it)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I used Velcro on mine so I could move them around as needed when I set them up. It does make a difference as to location on them.
They make adhesives for these to stick to about any surface -
I can't use the blue or I would get em.
Great price. Somebody needs to jump on this.
GLWS-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I use thumb tacks for mine. They are so light you can get by with one in the middle at the top if you mount it 2x4. Otherwise, you need one in each top corner if you mount it 4x2.
As had been said, these things work great. However, you have to be careful because it is easy to over install these and really deaden the sound.Lumin X1 file player, Westminster Labs interconnect cable
