Why do LED flashlights need a solid state chip board to operate?
Grahamione
Grahamione Posts: 1
edited April 2011 in The Clubhouse
In regular flashlights it is just a contact from the bulb to the bateries. what dose the solid state do to the light to make the bulb brighter?
Post edited by Grahamione on
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
  • maximillian
    maximillian Posts: 2,145
    edited April 2011
    I'm an EE so I will answer... the chips are regulators that regulate power to the LED. Without the regulators the LED could go into a runaway condition. You see, LED's were originally developed using technology from the Roswell crash. As such they are not fully understood and if they overload they can open a gateway to an invading world. Either that or simply stop functioning. NOBODY wants to find out though so all LED flashlights by international law must carry these regulators.
  • BeefJerky
    BeefJerky Posts: 1,320
    edited April 2011
    i'm an ee so i will answer... The chips are regulators that regulate power to the led. Without the regulators the led could go into a runaway condition. You see, led's were originally developed using technology from the roswell crash. As such they are not fully understood and if they overload they can open a gateway to an invading world. Either that or simply stop functioning. Nobody wants to find out though so all led flashlights by international law must carry these regulators.
    Winning!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2011
    ^^ HeHe :smile:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • JustinHEMI
    JustinHEMI Posts: 198
    edited April 2011
    More than winning, bi-winning.
    Fronts: Polk RTi A9's
    Center: Polk CSi A6
    Surrounds: Polk FXi A6
    Sub: Epik Empire
    Receiver: Onkyo TX-NR809
    Amp: Emotiva XPA-3
    Blu Ray: Panasonic DMP-BD210
    Power: Monster HDP 2500
    Monitor: Panasonic TC-P60ST30
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2011
    Alien Winning!!!
    Awesome answer Maximillian!!!!
  • Jstas
    Jstas Posts: 14,849
    edited April 2011
    Grahamione wrote: »
    In regular flashlights it is just a contact from the bulb to the batteries. what does the solid state do to the light to make the bulb brighter?
    It doesn't make the bulb brighter. LED are semi-conductors, Light Emitting Diodes. They don't operate the same way as incandescent light bulbs.
    Also, LEDs usually require, like maximillian said, a power regulator and a switching diode or relay. Regular flashlights use the voltage output of the battery as a finite regulator since the battery cannot discharge at greater rate than it's peak and it continually drops the rate as the battery discharges. LEDs typically use a fraction of the voltage coming out of the battery and therefore need a regulator to step things down to their level. Regular flashlights also have a switch, your thumb moves it and it's typically just two sliding pieces of copper with wires soldered on to the ends.
    An LED though, since it uses such a low power level, won't work the same with a switch. The leads needed to endure the abuse your thumb causes on a flashlight switch would not be able to be fully energized with the current being used by the LED illumination circuit. The little LED would not have enough juice to even turn on. So, to alleviate that, they will use a switching diode or a relay which allows the switching circuit to use a higher voltage that then flips the relay on the lower voltage and operates the light.
    That and they do it just to piss you off.
    Oh, BTW, fixed your speeling in the quote.
    Expert Moron Extraordinaire
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2011
    I liked the aliens explanation better.
    heiney9 Posts: 25,221
    edited April 2011
    LED's are alien technology we gleened from Roswell in the 50's...........
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2011
    Jstas wrote: »
    Irony at it's best.
  • JustinHEMI
    edited April 2011
    Center: Polk CSi A6
    Sub: Epik Empire
    Amp: Emotiva XPA-3
  • exalted512
    exalted512 Posts: 10,735
    edited April 2011
    Airplay355 wrote: »
    Irony at it's best.
    Yea...you need to calibrate your sarcasm meter again.
    -Cody
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited April 2011
    Airplay355 wrote: »
    Irony at it's best.
    Fail.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Airplay355
    edited April 2011
  • Jstas
    Jstas Posts: 14,849
    edited April 2011
    Airplay355 wrote: »
    Irony at it's best.
    It was intentional just to grasp the irony with both handys!
  • maximillian
    edited April 2011
    For the skeptics out there... I know what I am talking about. I design specialized LED lighting for a living. Check out this baby I recently did. There's like 3 LED's on this board and the main one (off-camera - wires at top lead to it) consumes LOTS of power. All this stuff is needed. Some of the parts have to come from government approved warehouses too. Yes, that big chip in the center is a mini computer. It is there to make sure nothing goes wrong. If it does, then it shuts everything down. This board was a pain because of all the redundancy and backup I had to add. But I guess knowing how to navigate the myriad of regulations out there is what keeps me employed. This job is not for the faint of heart.
  • nadams
    nadams Posts: 5,877
    edited April 2011
    "There's like 3 LED's on this board..."
    You designed it, and you can't state exactly how many LEDs are on the board?
    :p
    Ludicrous gibs!
  • strider
    strider Posts: 2,568
    edited April 2011
    Worst
    Spam
    Ever.
    Wristwatch--->Crisco
  • Jstas
    Jstas Posts: 14,849
    edited April 2011
    strider wrote: »
    Worst
    Spam
    Ever.
    Oh, c'mon! Sometimes it's fun playing with spammers!
    Isn't it ironic? Like rain...on your wedding day? :tongue:
  • Airplay355
    edited April 2011
    Or likes 10,000 spoons when all you need is a crane to turn your boat ride side up?
  • Jstas
    Jstas Posts: 14,849
    edited April 2011
    Airplay355 wrote: »
    Or a free ride, when you've already paid.
