Javascript is about to make my head go boom
ryanjoachim
Anyone here familiar with it? I'm looking into learning how to build some mobile apps, just for something to do.
It was going fine until I got into variables...then my algebra came back to haunt me.
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
Don't think of variables as Algebra, just think of them as places to store a number, string, or other piece of data (object).Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Yes. Programming is simple. Even a Caveman can do it. :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Lulz... if the variables make your head spin, wail til you get to closures. That's some good times for sure! Hang in there, man. It all starts to make sense after a while. If you're using HTML5+JavaScript for your mobile apps look into some the JS libraries, where a good part of the heavy lifting is done for you. I loves me some jQuery. If you're working directly with Canvas there's fewer good options that I've seen. Good luck!
I'll need to take some classes during the summer most likely. I've been meaning to for years, but kids and women kept pushing that back. Now that I'm single, I might as well put my spare time to good use."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
halenhoang wrote: »
I'm already on there. I got through the XHTML portion, and was doing ok. Got to the start of the Javascript portion then crashed and burned."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
