Speaker / Receiver Question
nolec5
nolec5 Posts: 42
edited April 2011 in Speakers
Hi Everyone,
Here is my current setup:
Onkyo TXSR 607
Polk Monitor 50's
Polk CS1 Center
Polk RM95 Rears
PSW 125 12" sub
When I set this system up, I wanted something that was good quality and that I could grow into. I'm at the point now where I would really like to upgrade the front and center speakers and eventually the surrounds.
I'm having a real hard time finding/deciding on speakers that will work well with the Onkyo 607. Can someone please point me in the right direction?
My understanding is that the 607 does not have pre outs for an external amp, correct?
I've listened to a lot of speakers and really would like to get Polk RTi A9's or Paradigm Monitor 11's.
So...with that said...would I be better off starting over and getting a different receiver? Something like the Onkyo 808?? Or would my 607 run the A9's for the time being?
Thanks in advance!
Post edited by nolec5 on
    tonyb Posts: 33,019
    edited April 2011
    Your receiver can run them,but not to their potential. Thats a big jump, the monitors to the A9's, see what happens when that upgrade bug bites ?:smile:
    Which is why we always suggest a receiver with preouts, so you have a path to grow.
    A receiver,and possibly an amp is the ticket. If you jump on the A9's first,keep the volume down until you can upgrade the electronics.
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    Thank you for the reply. I know....hind sight is always 20/20, right? ;-)
    What about the A7's? Would my receiver run them any better? And would I see a drastic improvement over the monitors? In all honesty, my room is pretty small....10x16 or so with a small viewing distance...about 9 feet.
  • PrazVT
    PrazVT Posts: 1,606
    edited April 2011
    Receivers will run the A7s and A9s, but you won't hear what these speakers actually sound like until you pair them with high current amps. Clearer music, crazy bass response, a soundstage!
    I know from experience.
    So I'd suggest upgrading to the least expensive receiver that a) has pre-outs and b) has the other features you want, and then get a 2ch (or 5ch amp, budget permitting) amp.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    Can you suggest some receivers to look at?? I'd like to keep it in the 500-600 range...but not sure if that's possible. I was thinkig about that onkyo 808...found it as a refurb for 599.
    Also, ive never shopped for home theater amps....can u give me an idea how much they can run, where to buy....brands, ect?
  • SRTer
    SRTer Posts: 372
    edited April 2011
    You always look in to a pioneer elite SC-35 or 37 and I'm sure you will like.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • brgman
    brgman Posts: 2,859
    edited April 2011
    I am using the 808 as a pre with a sunfire amp and it works great.i got mine off amazon and got a great price with all the percs of buying at a brick and mortar.good luck.
    I’M OFFENDED!!!!
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    I think I've seen someone else recommend that pioneer too....think it is in the 1k range. I was looking at a factory refurbished onkyo 808 for $599 which seemed like a good deal. I'm torn right now....have the budget to do the speakers....or the receiver...but not both at the moment.
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    Brgman....what speakers are you pushing with the 808?
  • brgman
    brgman Posts: 2,859
    edited April 2011
    well i am not really pushing with the 808.i use it as a pre for a sunfire 405x5.
    before i got it i was driving sda 2's and rta12c's but the addition of the sunfire was like going from a chevy impala to a top fuel funny car.i drive 3.1tl's or 2.3tl's with ease now.
    if you buy the speakers before you have the juice to drive them you are setting yourself up for possible damage to them not to mention the fact they will not sound anything like they should.don't put the cart before the horsepower.
    I’M OFFENDED!!!!
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2011
    Looks at www.accessories4less.com for your receiver. Plenty of options in your price range. Here's a great choice for only $350:
    http://www.accessories4less.com/make-a-store/item/MARSR5004/Marantz/SR5004-90w-X-7ch-Home-Theater-Surround-Receiver/1.html#!more
    Marantz will mate well with the RTiA speakers you're looking at. It has preouts but you can probably hold off on buying an amp for now. More money for your speakers :wink: .
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited April 2011
    nolec5 wrote: »
    brgman wrote: »
    nolec5, since your budget can not accomodate to replace both the speakers and receiver at once you can start replacing either one you feel is more pressing (receiver or speaker) first. If you replace the receiver first, you could be surprised how the 50s performs with the added power which can give you a break until extra budget is available to replace the remainder. Now, if you replace the speaker first, the main thing is not to drive them too hard in order to avoid clipping. Those RTi A9s need a little juice (minimum 50 watts) even at their lowest rating so you might not want to wait too long to replace your AVR.
    http://www.polkaudio.com/homeaudio/rtia/specs.php
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    Thanks everyone...this has provided me with great direction. I really thinking going to go with a new receiver.
    I really like the feature of pandora radio through receiver...which the 808 had. Are the marantz receivers much better then the onkyos? Haven't heard much about marantz and I think best buy recently stopped carrying onkyo bc of quality issues.
  • PrazVT
    PrazVT Posts: 1,606
    edited April 2011
    You can get the 708 for ~$650 and it has Pandora + pre-outs. Marantz and Denons share the same parent company I believe. Denon and Marantz are fine too (I have a Denon), but getting one w/ pre-outs usually involves looking at the >$1000 models.
    As long as you're getting the network features, perhaps Audyssey DSX, and maybe 3d if you want it ..you should be good. And the 708 has all of those.
    The Pioneer VSX-32 can be had for a similar price with similar features -but I didn't see Pandora listed.
    Home Theater:
    2 Channel:
  • nolec5
    nolec5 Posts: 42
    edited April 2011
    I was actually just looking at the 708 on accessories4less....Seems like a great option at $479
  • dnoyeB
    dnoyeB Posts: 114
    edited April 2011
    I had an HT-RC270, $449 on accessories4less. Pretty much the same as 708 minus a few advanced features like trigger output and rs232.
    Anyway, whatever AVR you get, be sure to get pre-outs. Pre-outs oddly come on the higher end AVRs that already pack plenty of power.
    What I ended up doing is putting together a list of AVRs with preouts. Then stalking eBay.
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
  • jbooker82
    jbooker82 Posts: 1,627
    edited April 2011
    I haven't had any problems with my onkyo 808 but I have only had it for a couple of months. It runs my system pretty well, but I am saving and on the look out for an amplifier. Sunfire would be sweet, but an emotiva is more budget friendly.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
