Who has a Integra pro/pre?
bdtae5656
bdtae5656 Posts: 235
edited March 2011 in Electronics
Im looking for a pre/pro for HT, either the DHC-80.1 ,80.2 or the 9.9. Ive been reading the AVS forum and like what im reading on Integra. Any thoughts from owners? Problems or dislikes?
Thanks,
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
    EndersShadow Posts: 17,722
    edited March 2011
    I have a DTR 5.9 (not really a pre, but has pre-outs). I like it just wish it had more than 2EQ, but that was the only version of room correction out at that point. This isnt something you will run into with the newer models.
    Only problem I have had with it was the capacitors on the HDMI board went bad after 1.5 years. This problem was the same one as the Onkyo XX06's had so it was good I had a 3 year warranty since it got fixed with no out of pocket on my part.
    So they are decent. I personally am probably going to upgrade to something Marantz (AV7005 probably) due mostly to looks (for the wife). The Integra's just look ugly :smile:.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2011
    You can buy the Marantz av7005 for $1100 street price or you can buy a integra 9.9 for $650 - $900
    I would go with an nad pre as they have the removable cards so you may upgrade rather than toss it
