2 sub connection(identical)
The Polk directions for hooking up my speakers (polk rm6200) to a sub are to hook the front speakers to the sub & then to the front speakers...How do I hook up 2 of the same subwoofers?
Run the front left speaker connection from the receiver to the left sub and then to the left front speaker and then the front right the same way,or something else??
Set the speaker setting to large & sub to off?
Am I close or completely off base?
My receiver has the Audessy speaker setup, how would that work?
any constructive advise would be appreciated..........
Post edited by gueromeister on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2011
    You could do that, or you could split the Sub Out signal from your AVR to the Line In connections on the sub. Then, turn the sub ON in your AVR. This option would give you/Audessy some control in setting and adjusting the sub level. Good luck! :smile:
