RTi and Onkyo 608
Hi all. New to this forum. New to Polk Audio products. A pleasure to be here.
Just purchased pair of RTi 7, RTi 1A, and a CSi A4.
I have an Onkyo 608. Which settings do I use in Onkyo?
I assume the RTi 7s are FULL BAND.
Which settings for 1A and A4?
Choices: Full Band, 40Hz - 200Hz, including an 80Hz THX.
Cant seem to find this spec in speaker manuals of on web site.
Let me know of any other settings or tweaks I should be aware of.
Thank you
Larry
Thank you
Larry
Post edited by cuda1111 on
Do you have a sub? If so all speakers should be crossed over, otherwise run RTi A7 FULL and cross the others around 80. With a subwoffer I would still cross over RTi A7 at 40-50 Hz.
Experiment to see with what sounds best in your room. -
Sub woofer YES, an older powered Sony.
Have it turned down about 1/4, other wise its way too much. Also have double bass turned off for regular TV.
I will work by ear. That seems the be the best way. Just want to make sure I am technically correct to avoid damage to anything.
Might try the mic to tune everything. Will that also adjust the crossover?
Thanks for your help! -
Get a csi6 to make that onkyo sing as its the best upgrade for Ht and I love onkyo's 2ch performance as it whooped the pants of my pioneer elite vsx01
polkfarmboy wrote: »Get a csi6 to make that onkyo sing as its the best upgrade for Ht and I love onkyo's 2ch performance as it whooped the pants of my pioneer elite vsx01
I could tell the Onkyo TX-SR8055 (130 Watt) did have a rich warm sound when I listened to in against a the Pio Elite VSX-23THX (110 watt) at the Magnolia in Best Buy on Matin Logans and Def Tech Towers.
However, i still bought the Pio because it work nice with the user, iPod adapter was included and the price was nearly $300 dollars cheaper. Sometimes, i think is still should have bought it.
Now I got SC-35.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
