to buy or not to buy
druggo
Hey all
looking for some ideas. am wanting to install my home theatre system (been thinking/ researching for awhile now). was looking to get 3x owm3 to feature as front left, right & centre. another 2 of the same for surround. as yet have not looked at rear speakers as the room size is not that big. to compliment this i would like to use polk audio psw111 8" sub or the psw505 12". for the bedroom i would also like to use the owm3, another set. my question is this, are these owm3 any good. what i like about them is the different mount options & how they can blend into the background. thats propably the main reason as to why i want to use these speakers. i was told that when building a home theatre system its better to spend your budget on good speakers as AC Receivers, with most techy things these days always require upgrades after 2/3 years. any suggestions/ comments will be most appreciated.
Post edited by druggo on
Welcome to the Club. I have no experience with the speakers you are thinking about so I can't really help there but what I can say is....the capitals key is your friend if you don't want your posts to look horribly jumbled and confusing to read.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Thanks for that. Will look into them asap.
