psw505
67jason
Two PSW505's are better then one. :biggrin:
That is all.
That is all.
Post edited by 67jason on
Yep, I can 2nd that...
absolutely.Yep, I can 2nd that...
I started putting together my system in January, been running a single 505 for about a month and found a new in box craigslist deal on a second 505, picked it up tonight and installed.....and I gots me a very big :biggrin: right now.
This weekend I will experiment with locations for the subs in my room. Currently I just stacked it on top of my other 505 near my front right monitor 70 and it sounds very good. -
I tried that, my room is pretty damn big so I ended up putting it in the opposite corner and it definitely helped even out the bass response throughout the room. I ended up trading my 2 505's for an SVS & amp (thanks to craigslist) and it was definitely a huge upgrade, but I miss dual subs and want another one now!
Hi guys
I have a psw505 i bought new. I am in New Zealand and looked to see on the polk site if they are still current.They were not listed. I want another one.
Do you have any knowledge if you can still get one new? -
Hi guys
I know you can through amazon: http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0/ref=sr_1_1?ie=UTF8&qid=1301636930&sr=8-1
