Klipsch SW series subs
HTguru1982
Anyone have any experience with these? I just picked up the SW 112 on closeout at UE. I know most people on here dislike their subs and they're probably not worth their full retail price but for what I paid, I don't think I could do better. The thing I like most about the 112 is that it's not boomy like my Sub 10 is. Bass is well defined and impactful. I just put in Master and Commander and was blown away. My only regret is that I can't add a second sub - that was the last one they had :frown: .
http://www.klipsch.com/na-en/products/sw-112-overview/
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
I have a little Klipsch SWV sub that I use with my Dahlquist DQ10s. I've tried 4 or 5 different subs with them and like this one the best. I have nothing bad to say about Klipsch subs.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
I have not heard these new subs...but the design looks a bit like a Velodyne to me? Polk also uses the slot port on their DSW subs?
I suspect this new design probably makes them a bit less boomy than the older SUB 10/12 series which could play loud for LFEs but always seemed slightly out of control on music to me? Actually, I would like to hear one of these out of curiosity.
My sub is nothing special...a 300 watt RMS 12" Boston Acoustics pretty much in the same price range/category as that Klipsch and the Polk DSW600? It serves my purposes for now.
Before the Sub10, I had a nice little RW8 from Klipsch and while it wasn't particular great for movies, it was perfect for music - still wishing I hadn't sold it. The SW series is supposed to be a step up from the Synergy subs and after comparing the two, I'd say that's about right.
One of the first things I noticed upon opening the box is that it does looks like a Velodyne sub. I think it's a step in the right direction. Their older subs just screamed, "Look at me!" Looks like they redesigned all of their subs and definitely for the better.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Subwoofer: SVS PB10-ISD -
I have an 8in pwrd sub from the 500 H/T set and have had nothing but pleasure out of it. I personally adjust it at about 1'oclock and this adds a little punch.For my apt and financial needs it fits perfectly right now.It goes well w/ my Yamaha RX-V665-avr.....LW2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I love my Klipsch RW-12DPolk CS1 Series II
Monitor 30s
Monitor 40s Series II
Klipsch RW-12D
Onkyo TX-SR308
Samsung 46" LED-LCD
Samsung BD-C5500 (Don't Recommend)
