Center channel speaker to go w/SDA 1C
rromeo923
rromeo923 Posts: 1,513
edited October 2011 in Vintage Speakers
I am looking for a center channel to use w/SDA 1c's.
Found this deal online and was wondering if this will do the job.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290105
What do you think?
I got static in my head
Post edited by rromeo923 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2011
    Many use the csi a6 and cs350ls
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2011
    leroyjr1 wrote: »
    or a CS400i. Personally, I think the A6 is a tad bright for 1Cs.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited March 2011
    CS10 will not do your SDA's justice. CS350 or CS400 are both good choices. Any models produced after those will be too bright to match well with your fronts.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • leroyjr1
    edited March 2011
    Ron Temple wrote: »
    The sl2000 tweeters are bright also.
  • gwg_97
    gwg_97 Posts: 332
    edited March 2011
    I use a csi a6 with my 1Cs and it works very well.
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • rromeo923
    edited April 2011
    Well found a CS 350 in great shape for $100. It matches well w/ the 1C's.
    I sold my Def Tech CLR3000 so this was a downsizing. However I def came out ahead on the $$ end. Wife happy. I was afraid I would not have enough bass w/ the CS 350 and the 1C's but I was pleasantly surprised and actually thought the bass was better than my Def tech system (power monitor 900's and the CLR 3000)
    Anyway another Polk speaker. That makes 9 "new" speakers in 90 days. :biggrin:
  • gdb
    gdb Posts: 6,012
    edited April 2011
    (Polk ****):biggrin:
  • nspindel
    nspindel Posts: 5,343
    edited April 2011
    rromeo923 wrote: »
    We've created a monster :biggrin:
  • rromeo923
    edited April 2011
    My son who is 23 after hearing my speakers went on craigslist and found himself a pair of 8t's. Runs in the family.
    :smile:
  • JimMueller
    JimMueller Posts: 100
    edited October 2011
    I have SDA-1C's with the RD0-194 tweeters. I'm looking to replace my CS100 center. Which center(s) will be have the closest timbre matching to the 194's? Support suggested CS10/CS20/CSiA4 as far as what I can buy new. I can fit a center almost 8" tall on my lower shelf (effectively on the floor), or up to 5" tall on the upper shelf. Or I can try to mount them above the 54" plasma, which is on a HDTV stand.
    Any strong mounts I can use to at least listen to the center oriented above the tv?
    Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
  • rromeo923
    edited October 2011
    Well as things have evolved I no longer use a center channel. In fact I go rid of my 7 channel amp (replaced w/2 channel tube integrated) and only use a 2 channel setup. Works great for music and movies. That is how I now roll FWIW.
    heiney9 Posts: 25,217
    edited October 2011
    Place your ears perfectly in the center of the speakers while being equidistant, the same length as width between the speakers.
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    JimMueller wrote: »
    I am currently using a CS10 with my 1C's (with 194's) and it works fine. It was not a good match with the 2000's.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • WilliamM2
    WilliamM2 Posts: 4,781
    edited October 2011
    JimMueller wrote: »
    I've found the CSi40 to be a good match with my SDA1C's and 194's. I use an older model of this to mount the center above the TV. Barely visible, and very strong, max wieght of 100 lbs.
    http://www.amazon.com/Adjustable-Component-Shelf-v-Equipment/dp/B00155PSXS/ref=sr_1_1?ie=UTF8&qid=1318718782&sr=8-1
  • chandler9a
    chandler9a Posts: 878
    edited October 2011
    I'll be using a Monitor 10 with an RDO 194 for a center with my 1C's. Not that its the best use of a great monitor 10 but I dont have anywhere else to put it so...
  • JimMueller
    edited October 2011
    Tried the phantom speaker and I didn't care for the dialog when not in the sweet spot. I would prefer a current product over vintage, easier to return if I don't like the sound. I think I'll try the CS20.
  • 20hz
    20hz Posts: 636
    edited October 2011
    I just sold a cs350 for way to cheap I still got a cs300 .
    IMO I would go old school to match it up , kinda like putting centerlines on a 51 chevy it will never match .
  • falconcry72
    falconcry72 Posts: 3,580
    edited October 2011
    The best match for a vintage Polk is a vintage Polk: Monitor 5,7, or 10. The bigger the better. Just make sure it uses the same tweeter as your fronts.
    The best match for a 194 is a 194, the best match for an SL-2000 is an SL-2000. Period.
    If you'd prefer to use something more modern, so that it won't sound as good, the CS-350LS does a good job matching the 194; it doesn't match the SL-2000 as well.
  • JimMueller
    edited October 2011
    It appears the Monitor 5/7/10 all have their tweeters on the end of the enclosure. I can't fit that enclosure on the HDTV shelf. If I put it on the floor in front of the shelf then I find it tacky besides it being physically further out than the mains. If I mount it above the plasma, then it's really tall and I'd need to mount it upside down to keep the tweeter near the screen. I also don't know if those vintage speakers are shielded (may not be applicable to plasma though). If I mount it horizontally then I need to offset the speaker to center the tweeter between the mains which won't work with my shelf. So while this might be the ideal solution, it doesn't seem practical for my environment.
    Any chance I can install a 194 tweeter in a more recent horizontal model without other side effects? I found a CS350LS for sale for $90 on the west coast, I'll see if I can grab it.
    I just spoke with support again and got a different guy this time. He suggested, in order of preference, a CS400i, CS400, or a CS1000p.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited October 2011
    rromeo923 wrote: »
    That was exactly my thought when I read the OP's first post.
    In my opinion, the SDA's phantom center channel is the best center out there. And then you can devote the money you would have invested in a center channel amp/cables toward improving your 2-channel amplification.
    By the way, your center channel needs to be centerlined on the horizontal line running between your left and right channel tweeters (if you have a tweeter array, the line height is established as the arrays measured mean decibel average). If you place a center 3 feet above that horizontal line, you need to place a second center 3 feet below that horizontal line.
    So as in the image below, the white horizontal line is slightly above the distance between the 2 tweeter cones as I believe the 1C slightly rolls off the lower tweeter. A second center needs to be added below the line as the first center was added above the line.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
