Question about 1.2TL wiring
tugboat
tugboat Posts: 393
edited April 2011 in Vintage Speakers
I was replacing the OEM gaskets with Mortite and noticed something about the wiring of the third from top dimensional driver wiring. All the other drivers had a green wire for negative and a blue for positive, but this one had two blue wires for the positive and one blue and one green wire for the negative. I decided to check the wiring diagrams and it says the positive is blue and has a wire marker on it. However, the wire marker is actually on the blue and green wires where they are crimped and that's the negative side, not positive like the diagram states.
So is this the way it is? I have attached a picture.
Thanks.
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Post edited by tugboat on
    F1nut Posts: 51,776
    edited March 2011
    That is wired correctly.
    Toolfan66 Posts: 18,065
    edited March 2011
    Jesse is right it is correct, do you see a little green ring around the blue wire???
  • tugboat
    tugboat Posts: 393
    edited March 2011
    The green marker is around a blue and a green wire on the negative side and the positive side has two blue wires and no marker. The wiring diagram should have stated that the wire marker is on the green and blue wires on the negative side if the picture I attached is correct. Instead it states that it is around a blue wire on the positive side (which is is clearly not).
    edited March 2011
    It is wired correctly. I have the same speakers, and went through the same thing a couple years ago..
  • tugboat
    tugboat Posts: 393
    edited March 2011
    I believe it is wired correctly. I trust the replies I got. My issues is that nothing about the way the wires are connected and marked match up with the wiring diagram created by Polk and placed in the forum for download.
    I wonder if any of the 1.2TLs build have wiring matching that in the wiring PDF.
    Thanks for yours and F1's input.
  • xoaphexox
    xoaphexox Posts: 247
    edited April 2011
    Just cracked my 1.2TL open to do some drilling for Larry's rings - mine are wired just like yours - opposite in this regard of what the wiring diagram says. It must be a mistake in their documentation.
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • tugboat
    tugboat Posts: 393
    edited April 2011
    xoaphexox wrote: »
    Thanks! I find it crazy at times when the schematics and diagrams we rely upon aren't correct. In this instance it wasn't an issue as it wouldn't blow up and this forum can get you all the info you need to get on the right track, but when it's something like a power supply board the diagrams and such need to be correct.
  • xoaphexox
    edited April 2011
    Tell me about it! I restore a lot of vintage audio equipment and Sansui service manuals in particular are terrible - often times confusing things as important as NPN and PNP. Keeps you on your toes!
