subwoofer connection
beric
How to connect a300 watt powered sub to a NAD C372 without frying one or the other, or both.
Post edited by beric on
What kind of sub? (make and model)
got the answer from Paul at National Sound. A Y connection from the pre out to the sub cable. Works a charm.
are you running dual subs?Fronts -Polk Rti-A9's
Center- Polk Csi-A6
Sub -M&K 12"
TV Mitsubishi 73" DLP
Sony 110x5 (old needs replacing)
