Crossovers Rebuilt Night and Day!!!
jim 249
jim 249 Posts: 347
edited March 2011 in Vintage Speakers
:biggrin:Hi All; I just completed the crossover rebuild in my 2.3TL's. The
difference is night and day. I used Mills resistors and Dayton caps.
The highs and mids opened up a lot, like a
thick veil has been lifted from the speakers. Any one looking to upgrade
any speakers should first do the crossovers and then think about
changing the drivers. After listening to mine, the driver replacement
is out for me except the one bad MF-6510, available from Polk for
$48.00. I learned this trick for fixing stripped holes in particle
board after I stripped a couple of holes while assembling my ping pong
table. Remove the screw and start putting toothpicks in the stripped
hole breaking each one off until the bad hole is full, then reinstall
the screw and it will tighten right down. I did the same thing for the
bad passive holes on the speakers except I used just one toothpick and
hot glued it in, then snipping off the ends with wire cutters. All but
one held because that one hole was really stripped out. On that one I
jammed in two toothpicks and broke them off and reinstalled the screw
and it tightened right down. A real neat quick fix that works. Thanks
for all the help you guys have given me on this site! Polkers are all
great!!!!!!:biggrin:
Post edited by jim 249 on
  • OldmanSRS
    OldmanSRS Posts: 419
    edited March 2011
    Good to know. I used Dayton caps as well and they were an improvement over the 20 year old caps. Didn't even need to break them in biggrin.gif and they have not improved or changed in the last 2 years. The price is right too.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • TennMan
    TennMan Posts: 1,266
    edited March 2011
    I intend to use the Dayton caps when I do the upgrade. I've already upgraded to the RDO-194 tweeters. I hope the Dayton caps are a good match for them.
    F1nut Posts: 50,769
    edited March 2011
    IMO, it is well worth the extra money to go with Sonicap's.
    The toothpick trick is ok in a jam. A better and longer lasting method is to drill out the stripped screw hole, cut a wooden dowel of the appropriate diameter to size, glue it in place, drill a pilot hole and it's as good, if not better, than new.
    then think about changing the drivers.
    Unless a driver is bad, why would you think about changing them?
  • jim 249
    jim 249 Posts: 347
    edited March 2011
    I have read many times on here of people upgrading their tweeters to the newer RDO's. The ones I have sound great with the rebuilt xovers.
    F1nut Posts: 50,769
    edited March 2011
    Tweeters are not drivers and the RD0's are a vast improvement over the originals. You should try them.
  • jim 249
    jim 249 Posts: 347
    edited March 2011
    I would think any thing that produces sound would be considered a driver?
    nooshinjohn Posts: 25,466
    edited March 2011
    jim 249 wrote: »
    I learned this trick for fixing stripped holes in particle board after I stripped a couple of holes while assembling my ping pong table. Remove the screw and start putting toothpicks in the stripped
    The best fix for stripped holes in SDA's is getting yourself a set of Larry's driver rings. They run about 100 bucks for the 2.3's, and the improvement in performance over the old way of mounting them is stunning to say the least. When you mount them, get some Armacell insulation tape.. (pn# TAP18230) and cut it into 1/2" wide strips and run the strip around the driver in the same place as the stock gaskets. Your jaw will hit the floor when you experience the much deeper, tighter bottom end. You will also notic much more deatil in the mids....
    F1nut Posts: 50,769
    edited March 2011
    Nope. There's tweeters, there's mid-drivers, there's woofers, etc. Don't want to take my word for it, Google it.
  • aboroth00
    aboroth00 Posts: 1,106
    edited March 2011
    They're all drivers. Tweeter, mids, and woofers are just subdivisions. A mid can be used a woofer or a woofer can be used as a mid, so on.
    It's like how we call each driver, tweeter, a speaker as well. But I believe the word transducer and driver can be used interchangeably but the word driver seems to be exclusive to the audio world. Honestly, it's all semantics but I can be very wrong or very right.
    2Ch Tube Audio Convert
  • aboroth00
    edited March 2011
    I was wondering why you swapped out the resistors as well. I was under the impression that resistors never go bad and are really constant factors which don't vary in the XO circuit.
    However changing out old caps seems to be across the board the thing to do. Did you replace all the caps or just the electrolytics? I was planning to just replace the electrolytics and leave everything else intact and stock.
  • Systems
    Systems Posts: 14,873
    edited March 2011
    Absolutely.
    Here is a pic of myself after upgrading to the Sonicap's:
    I think they are 15% off right now.
    Testing
    Testing
    Testing
  • Systems
    edited March 2011
    aboroth00 wrote: »
    Replace all of them.:wink:
    Testing
    Testing
    Testing
    F1nut Posts: 50,769
    edited March 2011
    aboroth00 wrote: »
    Eh, ever try using a tweeter for a woofer? GTFOH.
    How about silly.
    F1nut Posts: 50,769
    edited March 2011
    aboroth00 wrote: »
    Because wire wound, non-inductive resistors sound better.
    Kinda like rebuilding half of an engine.
  • aboroth00
    edited March 2011
    How about silly.
    Driver=transducer=speaker. they can be used interchangeably. I found it odd you can call a tweeter a speaker, but it does happen and people do use that terminology. It's not wrong. You're not absolutely right.
  • aboroth00
    edited March 2011
    More like replacing the parts that have gone bad. I've been under the impression that only electrolytic caps need replacing due to the oxidation of the chemicals inside the cap making it go bad. Other caps usually don't need to be replaced because they don't go bad as soon as the electrolytics.
    I do understand that resistors with no inductance will suffer from less unwanted inductance, but is this really audible? The unwanted inductance seems like such a small factor to me What kind of inductors are in use in the current crossover if not tightly toleranced resistors with minimal inductance in the first place? Why not just use two resistors in parallel which would attain the same effect. I'm just saying be weary of "high end" crossover parts, but it sounds better what's to stop you from sinking a couple bucks into a resistor. I'm not quite familiar with the resistors in the speaker so I can't really comment on it.
    Has anyone replaced the caps then replace the resistors. I feel that most people usually mod their entire XO at the same time (don't want to take it out then place it back in) and the benefits of the new caps might obscure the small benefits from replacing resistors.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2011
    I've heard lots of audio geeks refer to tweeters as drivers. I've seen (in catalogs and such) and heard people refer to some expanded range drivers as mid-tweeters. And, I'm pretty sure the MW in all of Polk's driver model numbers stands for mid-woofer, not mid-driver. But F1's fingers cramp up if he goes longer than a day without arguing over something random and pointless on the forum, so I would expect this tangent to dominate this thread for another 5 or 6 pages of posts. :tongue:
    Anyway, I just put some Dayton caps, Mills resistors and 194's in a pair of 5Jr's, and I'm guessing it is the tweeters more than the caps, but the speakers sound different and better now. They're mellower in the high end, and I think that has to be the tweeter rather than the caps. I'll be doing another upgrade with Sonicaps, but I will say this for the Daytons... if you get the 1% you don't have to worry about trying to get someone to match them for you, and I haven't noticed a significant change in sound after the first 10 hours of use. The Sonicaps are reputed to have a roller-coaster burn-in that takes over 100 hours before you know what you got.
  • aboroth00
    edited March 2011
    On3s&Z3r0s wrote: »
    Let's just leave it at semantics and move on.
    But that's very cool, replacing the caps. Did you get a chance to measure the caps and resistors with a good DCM? I've heard the non-inductive resistors from Dayton aren't actually wired as a non-inductive resistor should be, reverse wound but instead they're just normally wound. It just has very low inductance. I wonder if anyone out there has tried a metal film resistor or just using a dayton resistor in parallel to match the "performance" of the mill's resistor. Honestly I'm not really convinced of all the resistor hooplah and millihenries affecting the sound.
  • OldmanSRS
    edited March 2011
    aboroth00 wrote: »
    That's what I did with the caps. Measured the stock resistors and they all came in under 5% tolerance. I'm not worried about the miniscule amount of inductance they might have and, like you, don't think it's audible.
    If a person is going to the extreme of replacing all the caps and resistors in the XO to insure the very best possible reproduction, they may as well change all of them from the laser pickup to the output stage of the amp to improve the entire audio chain up to the level of the XO.
    For me it's a matter of economics and the point of diminishing return but hey, I wont spend $80 on an HDMI cable either.
    No offense to anyone who wants to attempt to take it to the next level.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • TennMan
    edited March 2011
    On3s&Z3r0s wrote: »
    What amazes me is at the end of that roller coaster ride the people who install them always say the roller coaster stops in the very best sounding place. Just doesn't seem possible that it would be that way every time.
  • On3s&Z3r0s
    edited March 2011
    aboroth00 wrote: »
    ... Did you get a chance to measure the caps and resistors with a good DCM? I've heard the non-inductive resistors from Dayton aren't actually wired as a non-inductive resistor should be, reverse wound but instead they're just normally wound. It just has very low inductance. I wonder if anyone out there has tried a metal film resistor or just using a dayton resistor in parallel to match the "performance" of the mill's resistor. Honestly I'm not really convinced of all the resistor hooplah and millihenries affecting the sound.
    I did take the easy measurements for the resistors and caps (just resistance and capacitance). The Mills resistors didn't measure any more accurate than the stock resistors. In the 5Jr, they're a 1 ohm resistor and both stock and replacements all measured at 1.1 ohm. The stock caps measured 12.29 and 12.74 uF. The Dayton replacements measured 12.0 and 12.01! The Sonicaps I got for a different speaker project came in a bag marked "12uF 200V matched" and they measured 12.18 and 12.52. I know the performance of the caps has to do also with many factors unrelated to their capacitance measurements, but if I had it to do over again I would probably go with a different brand of caps with a tighter tolerance. I haven't heard the Sonicaps yet, so I might change my tune (so to speak) after that happens, but for now I'm a little disappointed with Sonic Craft's idea of what "matched" means.
  • aboroth00
    edited March 2011
    On3s&Z3r0s wrote: »
    Hmm... I haven't had the chance to measure any Sonicaps with my Fluke, but that doesn't seem too good. Should've asked for a return or more caps for your trouble!
    Honestly, I'm not at all convinced about the effects of different resistors, just put me in the "as long as the resistor works right group." Does the OP know what kind of resistor he replaced?
  • fbm211
    fbm211 Posts: 1,488
    edited March 2011
    Compare a mills resistor to a mundorf mox resistor and I bet you will hear a difference.
    And On3s&Z3r0s,You should call elliot and tell him your caps are not matched and maybe he will take care of it for you.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
    F1nut Posts: 50,769
    edited March 2011
    They are matched caps. Sonicap's are stated to have a tolerance of 5% and usually are closer to 2%. If you wanted 1% tolerance, you have to ask for them.
    As for the resistors. You act as though a couple of bucks per Mills is going to put you in the poor house. Really?
    Since some of you seem to be rather new at this, maybe you should give the guys that are not the benefit of the doubt that we actually know WTF we're taking about.
  • DON73
    DON73 Posts: 516
    edited March 2011
    Since some of you seem to be rather new at this, maybe you should give the guys that are not the benefit of the doubt that we actually know WTF we're taking about.[/QUOTE]
    Several of us are very new but there is a very interesting discussion going on in this thread. No need for WTFs and GTFOHs.:smile:
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • OldmanSRS
    edited March 2011
    And some of us might be new to this forum but have 37+ years of practical experience in audio and electronics. We enjoy the discussion and listening to others explain their results without being insulted. We enjoy the debate and think it is our right to bring our views to the table while be treated with a modicum of respect.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
    F1nut Posts: 50,769
    edited March 2011
    Respect is earned and I haven't insulted anyone yet, but I'm open to that possibility.
  • Face
    Face Posts: 14,340
    edited March 2011
    OldmanSRS wrote: »
    37+ years of audio experience and you still believe all resistors of the same value sound the same, come on now.
  • aboroth00
    edited March 2011
    Well why would you want to overpay for a part that costs cents on the dollar, it's just common sense.
    As anyone knows, you often times can't really trust your ears. And why would I want to trust someone else's ears?
  • aboroth00
    edited March 2011
    Face wrote: »
    Resistors of the same resistance values differ. I believe he knows that there are different types of resistors used in different applications. Mills resistors use a different type of winding than other resistors to decrease capacitance and inductance. However the amount of inductance added and the amount of capacitance of a regular resistor pales in comparison to the capacitance and the inductance of the circuit.
    Caps on the other hand are a little more dubious IMO. Resistors don't have the same variability that caps do. As for most people with older speaks, it's a great idea to change out all the older electrolytics, unless anyone has any objections? Unless someone can sway me to change out all the caps, only caps that are going to be changed in my newly acquired speaks are going to be the electrolytics. Course I'll check all the caps and resistors to be of the proper value.
