Surrounds
edited March 2011 in Speakers
Hi all,
So I have been planning a set up of Yamaha RX-v667, Monitor 70s for fronts, CS2 for center channel, Monitor 40s or 50s for surrounds and a PSW110 sub for a 5.1 setup.
Out of all of the above, I have ordered everything but the Monitor 40s/50s for surrounds. And after receiving the Monitor 70s, my wife is totally not buying my arguments for another set of rather large speakers for surrounds.
So if I was to junk the idea of Monitor 40 or 50 for the surround, do you gurus have any recommendations that would cost around the same and are a little smaller?
Post edited by varang on
    edited March 2011
    Considering that the surrounds are not used as much you have a few options. You could go with some of the OWM series like the OWM3 or 5's. you could also get a couple of the new TL series satellites as well.
    there are also the monitor 30's. they are not much smaller than the 40's though.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
Welcome!
Welcome!
