Question about Sourround Speakers
KYFHO
KYFHO Posts: 76
edited March 2011 in Speakers
Hi -
I am looking to get folks opinion on surround sound speakers. I currently have a relatively small set-up consisting of RTi A3's up front with a CSi A4 in the center. I am trying to decide which rear speaker would sound best with this set-up. I am torn between the A3's, A1's, or the FXi 4 or 6. I am running a Denon 4310CI which has more than enough power to run everything. Please note I would go and audition these but am unable to since I am overseas (miltary in Japan). I had been running some old Sony bookshelf speakers but they bit the dust from the earthquake we just had. Any advice would be much appreciated!
    tonyb Posts: 33,072
    edited March 2011
    If you like the A3's you have up front, why not go with them for surrounds ? If you have the room of coarse. Any of your choices will work, the fxi will give a more diverse surround sound. How big is your room ?
    Or you could move the A3's you have upfront now to surround duty and move up a couple notches for the fronts. A7's would work well if floorstanders are up your alley.
  • KYFHO
    KYFHO Posts: 76
    edited March 2011
    I would love the A7's but the houses here in Japan have kind of weird layouts. The living room is 25x15. I considered moving the A3's to the rear just wasn't sure how they would look on the walls if I decided to go that route.
