PSWi8M Subwoofer to Mitsubishi LT055164 TV
rshasky
I'm a novice. I asked the Ultimate Electronics Sales person to pick out a compatible wireless subwoofer for my new Mitsubishi LT055164TV, which has a single LFE subwoofer pre-out. He presented the POLK Audio PSWi-8M subwoofer in a box, so I bought it.
I need help because the TV only has a single LFE subwoofer pre-out jack and the PSWi-8M only has 2 RCA input jacks and no LFE input jack. How am I suppose to hook this up? And will I still get the kind of performance and sound that I'm suppose to? In addition there is a phase switch for either 0 degrees or 180 degrees. What am I suppose to do with that?:redface:
Post edited by rshasky on
i just purchaced the same TV and want to add the same woofer that they reccommended to me which was the same as above Should would like to hear the answer to this question Thank you
Session Started with Agent (Jenny)
04/13/2011 06:25:28PM dave: "I'm a novice. I asked the Ultimate Electronics Sales person to pick out a compatible wireless subwoofer for my new Mitsubishi LT055164TV, which has a single LFE subwoofer pre-out. He presented the POLK Audio PSWi-8M subwoofer in a box, so I bought it."
04/13/2011 06:25:33PM Agent (Jenny): "Welcome back to Crutchfield Chat. How may I help you today?"
04/13/2011 06:25:50PM dave: "I'm a novice. I asked the Ultimate Electronics Sales person to pick out a compatible wireless subwoofer for my new Mitsubishi LT055164TV, which has a single LFE subwoofer pre-out. He presented the POLK Audio PSWi-8M subwoofer in a box, so I bought it."
04/13/2011 06:26:02PM Agent (Jenny): "It will still work."
04/13/2011 06:26:09PM Agent (Jenny): "You can use one input."
04/13/2011 06:26:13PM Agent (Jenny): "Did you get the sub here?"
04/13/2011 06:26:53PM dave: "no"
04/13/2011 06:27:12PM dave -
Just run a cable from the TV's LFE output to one of the two inputs on the subwoofer. It doesn't matter which one. If you'd prefer, you can also use a one female to two male Y-adapter to connect it to both inputs...but there should be no difference between the two connection methods. You'll still get the same performance you would if the sub had a dedicated LFE input.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
