Question about calibrating speaker level with sub
bryanr72
I searched, and didn't find exactly what I'm looking for. Do I use A or C weight for calibrating with pink noise? Also, once all my speakers are the same level, how do I calibrate the sub? I know I don't make the sub 75 decibels. Also, I have a floor sub, and 2 pairs of 8" subs in my Polk RT2000i. I read somewhere that I am to turn the level of the sub up until I ca tell where it is coming from, then down it back down a little so I can't tell where it's coming from.....does this sound right?
Thanks for the info!!;)
-Bryan
Equipment Used:
AVR: Sony STR-DA3000ES Digital 7.1
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Floor Sub: Infinity BU2
Equipment Used:
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Post edited by bryanr72 on
you would actually run them a couple or 3 db higher than 75 at least for home theater. set them the same way as all the others as far as procedure goes...try the c wieghting and try to calibrate all subs at the same timeMains: RT20Ps
Center: CS350LS
R. Surround: RT16s
R. Center: CS350LS
F. Effects: LS/FX
Sub: Titanic 15
Reciever: Yamaha RX-Z1
TV: 55 LED LCD
Interconnects:AR, RSF, MC
Speaker Cable:MC -
Yep, about 3dB higher on the sub than the rest of the spakers for HT calibration, and perhaps flat with all the rest for music, depending on your majority preference. C-weighted, slow response on the SPL meter. Also, I believe the Radio Shack meter reads on the low side for the sub, so you might want to consider upping the sub level another couple of dB's for HT.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
Other way around, Kev. Yes, the meter reads low on the sub tone, so the actual SPL is higher than the meter is indicating.
So running flat - 75 all around including sub - will actually result in the sub already running about 2-3 dB hot.
Setting the sub to 78-79 dB on the meter is really more like 6-7 dB hot.
Doc"What we do in life echoes in eternity"
SVS -
As usual, I stand corrected. Thanks, Doc.Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
