6510 Driver
jim 249
jim 249 Posts: 347
edited March 2011 in Vintage Speakers
Hi All; I have a 6510 driver that was not working in my 2.3TL's. In fact the only way I could tell it was not working was to use an SPL meter from the ratshack. After it was removed I noticed that one of the braided lead wires was not attached to the cone. In fact, it looks as if it was never attached. Is there any fix for this or am I sol. Thanks :confused:
Post edited by jim 249 on
    F1nut Posts: 51,763
    edited March 2011
    I believe they are simply glued in place. Look at how the good one is attached, then attach the loose one on the opposite side the same way.
    BTW, don't tell poor stuwee that I helped you, it might be more than he can handle.
  • jim 249
    jim 249 Posts: 347
    edited March 2011
    I talked with Polk Service and they informed that if the wire could be soldered back on it would not stay on for long. Their suggestion was to just replace the driver.
    Toolfan66 Posts: 18,054
    edited March 2011
    jim 249 wrote: »
    So you have nothing to lose "RIGHT?":wink:
  • jim 249
    jim 249 Posts: 347
    edited March 2011
    Right! Soldered it back on and it is working. Have to see for how long though. Was a difficult fix. Had to put a lump of solder on the braided wire and hold it carefully in place and a quick touch of the iron and was done. Did a light pull check and it was stuck on well. Nothing lost by trying! Thanks All!!!
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2011
    I did this to an old B52 Subwoofer I had back in the day. It worked fine afterward for a couple years. I still have the sub in the basement somewhere. I know it still worked when I went a different way with that cars stereo.
    nooshinjohn Posts: 25,919
    edited March 2011
    Lasareath wrote: »
    Keep a lookout for Vintage 6510 drivers and buy them as soon as you find them so that you'll have some in stock. I hate mixing up the new replacement drivers with the vintage ones. they don't look the same.
    This^^^
    There are a few 6510's on Ebay right now.
  • brgman
    brgman Posts: 2,859
    edited March 2011
    Great.I had those 6510's in the palm of my hand now i gotta bid against this cat.
    I’M OFFENDED!!!!
  • erniejade
    erniejade Posts: 6,321
    edited March 2011
    Can a 6511 be used in place?
    F1nut Posts: 51,763
    edited March 2011
    Negative.
  • Joe08867
    edited March 2011
    erniejade wrote: »
    No. The 6510 and 6511 have different ohm's ratings and are different in sound.
    edited March 2011
    brgman wrote: »
    Not at all interested in them. I will be moving soon and the place I am going will have plenty to snap up.
    Just don't bid against this cat....
  • brgman
    brgman Posts: 2,859
    edited March 2011
    lol.
    you are going to vintage polk parts heaven?!?!?:biggrin:
    I’M OFFENDED!!!!
