bearings going out on my car's ??? water pump or alternator
danger boy
danger boy Posts: 15,722
edited March 2011 in The Clubhouse
horrible squealing coming out of the car's engine.. can't tell if it's the H20 pump or alternator bearings. either way.. in read that on the 2000 Neon, it's a big hassle to replace the water pump..
the alternator is less of a hassle.. so I hope it's the bearings on that and not the H20 pump.
PolkFest 2012, who's going>?
Post edited by danger boy on
  • amulford
    amulford Posts: 5,020
    edited March 2011
    Are you seeing any water?
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2011
    Usually when bearings go out of a water pump, it will leak coolant. Take the belt off and wiggle and spin the pullies to see wich ones have excessive play or rough feeling. It could just be a belt tensioner or the belt its self. When belts dry out they squeel pretty badly
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • ken brydson
    ken brydson Posts: 9,023
    edited March 2011
    Are you sure it's not the belt itself?
  • nadams
    nadams Posts: 5,877
    edited March 2011
    Could also be a tensioner or idler pulley. Take the serpentine belt off and try turning each moving thing by hand. You should be able to tell which one is making the noise.
    Ludicrous gibs!
  • bikerboy
    bikerboy Posts: 1,235
    edited March 2011
    The tension pulley bearing was the noise maker on our ford f250. Remove the belt and spin all the pulleys and the alternator. Hope thats it and not the water pump. The belt could be old and needs to be replaced. You might replace it anyway because you will replace it if you replace the waterpump or alternator.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    If it is squealing and not grinding it is probably the belt. There is a weep hole on the underside of the water pump. Usually when the bearings go bad there is some antifreeze on the bottom of the pump. It is usually a small amount and not easy to find.
    Ben
  • ken brydson
    edited March 2011
    Easiest way to eliminate the belt as the problem is with the engine running spray some water on the belt with a spray bottle. If it stops squeeling you know it's the culprit. I had the same issue on an old F250 I had. Thought it was something else and ran by the parts store and they shot it with the water bottle. Squeeling stopped (for a minute until it dried)
  • Face
    Face Posts: 14,340
    edited March 2011
    You don't have mechanics in Spokane? :biggrin:
  • danger boy
    edited March 2011
    Face wrote: »
    ha ha ha!
    we do... but I like to check in here first.. true it could just be the belt... i'll do the spray bottle trick first..
  • amulford
    edited March 2011
    Hell no, got a dozen shadetree wrench monkeys in cyberspace. WTH is wrong witchoo???
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2011
    I had the same problem with my water pump Al. It turned out that the belt was fine but the pulling on the water pump would seize from time to time. Either way there was always leaking water present.
    txcoastal1 Posts: 13,519
    edited March 2011
    danger boy wrote: »
    ha ha ha!
    we do... but I like to check in here first....
    :biggrin:
    your screwed:biggrin:
  • danger boy
    edited March 2011
    no squealing sound today.. checked the belt.. looks good... not seeing any dripping from the water pump.. but the car is due for it's 90k service.. so it'll go in early next week to the shop.
    when revved up though... it appears there is to much movement in the small engine... so maybe some of the motor mounts are broke too... i dunno
  • JimKellyfan
    JimKellyfan Posts: 696
    edited March 2011
    If you have a 1/2" or 3/4" PVC pipe piece (chunks cheaply sold, 8' sections cheaper yet). Use that as a stethoscope (carefully) while running. Place the PVC piece carefully around. The loudest part will hurt your ears maybe, as it will be a louder area. Again, caution when searching.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
