polk audio rtia 7 tower speakers.
crash68
has any one ever compared the rtia7 to the monitor 10a , which is more musical and are the rtia7 a better speaker. will be pushing this a system with marantz ,amp sm-7 pre amp sc-7 and tuner st-8 ,looking for the best sounding speaker, both have good reviews.
Post edited by crash68 on
I wish someone would comment on this too. I'm picking up a pair today, but I would like to see what other think. I'm making the Polk RTi A7's my rear speakers. Therefore, it might not matter much.
I hear people saying that they are on the bright side as far as sound goes for music.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
Probably not a lot of people have both of those. The RTiA7 is a nice speaker though. You should be happy with it.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Is there a reason why you think a lot of people don't have the Polk RTi A7's? They are not terribly expensive.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Yeah, I would say they are for a surround application. Consider the size too, in a smallish room it would be hard to situate big floorstanders. Add in furniture and space gets cramped quickly. Also not as much detailed sound is routed to the surrounds, music is a different story of coarse, so for HT, in most cases it may be over kill. Then add the WAF, and you will get a nice comfy pillow on the couch to use.
I would rather spend the coin on dual subs, matching subs, up front than on a huge speaker for surround duty, thats just me though.HT SYSTEM-
lsi 9's -
I believe what was meant is that a lot of people probably don't have a set of each... not separately.Polk CS1 Series II
Monitor 30s
Monitor 40s Series II
Klipsch RW-12D
Onkyo TX-SR308
Samsung 46" LED-LCD
Samsung BD-C5500 (Don't Recommend) -
You, sir, are a winner.Turntable: Empire 208
Arm: Rega 300
