MIT AVT2 vs AVT1 bi wire
erniejade
I am debating between the MIT AVT2 or AVT1 bi wire. They would be replacing my Audioquest type 4 or my Audioquest Crystal.
Has anyone compared the 2 sets? I am still up in the air on the speakers I am going to use. I have just split my basement and going to be doing a speaker shootout to see whats going and whats staying.
So the speakers that i will be using might be Polk sda2.3, polk sda 1.2, Carver amazing original, JM labs 815, or vandersteen 2ce sig. The amp will be either the McIntosh 2105, or sunfire 300X2 ( unless its the amazings then it will be sunfire sig II 625X2)
Any opinions either way? Is it worth the 150$ difference between them for the AVT1? n
Thanks as always!
Thanks as always!
