Damaged MM120
wervisser
I had my 2 MM120's 'in a box' but decided that I wanted something different. So I turned them a 180. I removed the black rubber that was supplied with the woofer to make sure the sealing was airtight and what do you think... I also ripped the coating off the woofer... WAAH!!!
Is there any way I can fix this, because this is so incredible lame!!! The only other solution is to put an neon light over the edge so you can't see the outer ring with the screws.
Best regards,
Best regards,
Sincerely,
Werner Visser
Werner Visser
Post edited by wervisser on
Uhm, okay... that sounds terrific. But I hope I can return them to my dealer also.. 'cause it's a pretty long drive from the Netherlands to America for the exchange to occur....Testing
Testing
Testing
