wierd SDA 2 problem, help?
knie0012
knie0012 Posts: 47
edited March 2011 in Vintage Speakers
Hey folks-
I have a pair of SDA 2's and I'm having an issue I can't figure out the cause.
On my left speaker, I have two sl2000 tweeters. The left one works the right one doesn't. I thought maybe the tweeter was bad. I took them both out, plugged the "bad" one in to the known working side, and still had nothing. Tweeter bad, right?
However, when I plug the good tweeter in the "bad" side, the good one didn't work on that side either. When I plugged the good tweeter back in its original side, it worked.
So, either its a weird coincidence that the right side of the tweeters on the left speaker is bad, along with that tweeter, or something else is going on that I don't know or understand the reason.
Can others follow the picture? Clear as mud?
Please help me.
Thanks,
Jason
Post edited by knie0012 on
  • knie0012
    knie0012 Posts: 47
    edited March 2011
    Not the original owner. The previous owner was the only other. They sat in storage the majority of their life.
  • danger boy
    danger boy Posts: 15,722
    edited March 2011
    plug in your SDA cable.. see if that solves the problem.
    PolkFest 2012, who's going>?
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    To be clear you are not using tweeters from the right speaker correct? What color are the wires on the inside tweeter, and the outside tweeter?
    Ben
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2011
    Do you have the interconnect cable?
    It is a black cable that goes from the left speaker to the right speaker. If you do not have it plugged in you will not get anything from the dimensional side.
  • knie0012
    knie0012 Posts: 47
    edited March 2011
    Not using the tweeters from the right side. Inside tweeter is black and white, and the outside tweeter is blue and white.
    The interconnect cable is connected. When it isn't, that left speaker has no tweeter working, and when plugged in, the dimensional tweeter works. The inside tweeter should work even if the interconnect cable isn't connected, no?
    F1nut Posts: 50,769
    edited March 2011
    Check the connection on the crossover.
    Correct.
