Polk C300.2 vs Kenwood KAC-7205
Vital
So i picked up c300.2 a few days ago. Don't really need one, was more of an impulse buy since it was still brand new in box, priced to sell and good amp all around (or so i've heard). I'm sure i'll find use for it one day.
After getting it i looked around a bit for other 2-channel amps just to compare and "see what's out there" since i never really payed much attention to 2-channels and stumbled upon Kenwood KAC-7205. Basically from specs these 2 amps are near identical - same size, same output...
Let's say if i was in the market for a 2-channel, which of these 2 would you recomend and WHY?? Never had or Kenwood's amps/subs/speakers before, only headunits so don't really know much on what to expect from them.
Kenwood is CEA-2006 Complaint and Polk is not since it was made before it to begin with, not sure if that really matters thou when talking about decent brands.
POLK C300.2
?150 watts RMS x 2 at 4 ohms
?220 watts RMS x 2 at 2 ohms
?550 watts RMS x 1 bridged output at 4 ohms
?requires 4-gauge power and ground leads
?fuse rating: 30A x 2
?dimensions: 13-3/8"W x 2-9/16"H x 9-3/4"D
THD at Rated RMS Power 0.1%
Signal to Noise Ratio 105 dB
Input Voltage 14.4v
KENWOOD KAC-7205
?170 watts RMS x 2 at 4 ohms
?250 watts RMS x 2 at 2 ohms
?500 watts RMS x 1 bridged output at 4 ohms
?8-gauge power and ground leads recommended
?13-3/4"W x 2-3/8"H x 9-3/4"D
THD at Rated RMS Power 1%
Signal to Noise Ratio 95 dB
Input Voltage 14.4v
POLK C300.2
Input Voltage 14.4v
KENWOOD KAC-7205
Input Voltage 14.4v
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Kenwood DNX 5140
Post edited by Vital on
Specs are specs... I would venture to say Polk amps are built a a higher standard than Kenwood.
Also the SNR is higher on the polk, and the THD is lower - if you're going by specs alone thats a tenfold better THD and 10db (8 fold) better SNR. Not that those actually make much of a difference, but that's if you look at numbers.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
The Polk is better built and puts out more than its rated power.polkaudio sound quality competitor since 2005
