nut replacement:)
sda2mike
sda2mike Posts: 3,131
edited March 2011 in The Clubhouse
anybody ever replace the nut on a strat copy? it's non- slotted..i'm about to perform the surgery on my 31 yr old ibanez..any helpful advice?
thanks
mike
Post edited by sda2mike on
  • megasat16
    megasat16 Posts: 3,521
    edited March 2011
    One or both? :biggrin:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • sda2mike
    edited March 2011
    ibanez was born with one
  • halo71
    halo71 Posts: 4,608
    edited March 2011
    I have replaced a few in my day. I always order parts from StewMac. What is exactly do you mean by non-slotted?
    --Gary--
  • sda2mike
    edited March 2011
    some guitars have a slot that the nut slides into...mine just sits there with glue to hold it in place
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2011
    Surely there's a synthetic replacement, no? :biggrin:
  • halo71
    halo71 Posts: 4,608
    edited March 2011
    steveinaz wrote: »
    Sure there is. Check StewMac.com for Tusq, Micarta....
    Mike, I have had literally 100's of guitars over the last 25 years. Not sure I have ever seen one where the nut slides into a slot.:confused: I prefer guitars with locking nuts myself, like Floyd Rose or Kahler Spyder equiped guitars though.
    There are other options out there than just replacing it with a standard bone or plastic nut. I would suggest a roller nut perhaps. I want to put one of a Warmouth strat I have but haven't gotten around to it yet.
    Here is a pic...
    --Gary--
  • sda2mike
    edited March 2011
    thanks for the replies...i ordered a Tusq replacement nut...i'm going through everything..pots, switch, pickups, tuners, jack and tailpiece..this one is a survivor! to me it's much prefered over the strats i've owned and played..i'm pondering whether to 'block' the tremelo or upgrade the wammer
    thanks
    mike
  • halo71
    halo71 Posts: 4,608
    edited March 2011
    Mike, post some pics dude! I am guessing with it having a standard nut it also has a standard type tremolo? I am not a fan of blocking a tremolo. Why are you thinking of doing this? Tuning issues perhaps?
    Also there are some DIY guys that will take a cow bone. Guessing rib bone. Boil it to soften it and flatten it. Then cut it making there own true bone nut for their guitars.
    --Gary--
