rti a7 tweeter
john Jarvis
any one have problems with the tweeters in the rti a7.
i have one not working.wondering what to do. or where to get a new one. have emailed polk but haven't heard back. speakers are 6 month old. but i got them off ebay so no warranty i suppose.
Post edited by john Jarvis on
no one has any idea where to get on or what i should be looking for as a match
I would see if when you swap the tweeters if it is the same issue. Also I would recommend calling Polk. They normally answer and have great support.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Call don't email, they sell replacement tweeters. How did it blow? Volume?
First thing is to pull it and see if it's even connected... if it is, then swap them as mentioned before. If that still does not make it work, then call polk and order a replacement. Mention your a club polk member and you will get a discount.
