PolkAudio Monitor 40 (pair)
yepimonfire
yepimonfire Posts: 256
edited March 2011 in For Sale (FS) Classifieds
Hate to part with these great bookshelves but i need the money. Asking $100 + shipping. Will ship using whatever shipping you like. They make great surrounds and are great for a second two channel system as they have enough bass for music, i always felt like they performed as well as a smaller floorstander in that respect. In my room i can get a response down to 50hz before they start to roll off. they don't have a very steep roll off either. Never noticed any port noise on them or breakup/distortion or anything running them in full range at reference volumes. They are about 16 pounds a pair. PM if you're interested
Specs taken from polks website,
Driver Complement
Mid/Woofer 2 - 5-1/4" Diameter (13.34cm)
Dynamic Balance Bi-laminate composite cone driver, magnetically shielded
Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance Silk/polymer composite dome, magnetically shielded
Electrical
Overall Frequency Response 47Hz - 25kHz
Lower -3dB Limit 57Hz
Upper -3dB Limit 24kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 - 125 w/channel
Efficiency 89 dB
Crossover 2.3kHz, second order high and low pass
Inputs Dual (bi-amp) 5-way binding posts
Dimensions
Cabinet Size 15-3/4" H x 7" W x 12" D
(40.01cm H x 17.78cm W x 30.48cm D)
Enclosure Type Vented via rear panel flared port
they are in near new condition besides one thing, at one point in time the grill cracked (not broke) and i glued it to make sure it wouldn't crack anymore and there is a small scuff on the edge of the grill, included in pictures.
P1010060.jpg'
